Emergency starting procedure???
Old Jul 31, 2006 | 01:16 AM
JoeMustang's Avatar
JoeMustang
Default Emergency starting procedure???
Hi Guys, my 68 mustang would not start when I turned the key, but had religiously until then. The battery and all seemed fine until then also. I could turn the key all the way to the right and NOTHING, except for the radio. I let her sit a while and she atarted right up and every time after that. What I am looking for is what steps to take incase this happens again so I can get it home and test to see if it's the solenoid or starter. Do I just turn the key to the on position, open the hood and put a screwdriver between the two small plugs on the front of the solenoid?? Or would someone have to hold the key all the way to the right in the start position?? I also thought it could be the neutral safty switch?
Thanks,
Old Jul 31, 2006 | 02:36 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Emergency starting procedure???
Sounds like neutral safety. If it is, take a jumper from the (+) side of the battery to the (I) terminal on the solenoid and the engine will crank. If it doesn't, the solenoid is bad and you need to jump across the BIG terminals...which is kinda hard on metal objects[sm=outcold.gif], but will work in a bind...
ORIGINAL: JoeMustang
Thanks,
Old Jul 31, 2006 | 06:14 AM
Shifty101Easy's Avatar
Shifty101Easy
mine does that sometimes........but my head light wiring harness was cut by the alternator fan....so its probably a diff situation.....
Old Jul 31, 2006 | 09:00 AM
Soaring's Avatar
Soaring
I ♥ Acer
Wiggle the shifter back and forth is the first thing to try to make sure it is in Park.
Old Jul 31, 2006 | 11:57 AM
JoeMustang's Avatar
JoeMustang
If I jump between the large cables, will the car start and stay running, or do I have to leave the key in the "run" position before I jump it. What I want to avoid id driving it somewhere and not being able to get home.
Thanks
Old Jul 31, 2006 | 12:36 PM
Twister's Avatar
Twister
1. does your shifter wiggle side to side?
2. a solenoid is CHEAP
3. a nuetral saftey switch is about $51.00 from Ford
Old Jul 31, 2006 | 12:42 PM
HungLikeATunaCan's Avatar
HungLikeATunaCan
Lots of times the starter on these old cars take a crap when it's hot out. I just went through this on one of my dads old cars. And it always happens as you explained it. Have someone sit in the drivers seat and hold the key to "start." Get something long and hard and tap on the front of the starter. It will generally start right up. It is time to replace the starter however.
Old Jul 31, 2006 | 01:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Thanks
Yes, if you jump across the solenoid (starter relay) you leave the key in the on position if you want the engine to keep running. However, if you have to do that to get the starter to turn over, then you need to replace the solenoid.
Old Jul 31, 2006 | 02:04 PM
JoeMustang's Avatar
JoeMustang
I will check the shifter for movement. Is the neutral saftey switch visible if I take the shifter cover off?? Is there any adjustment on it??
Thanks,
Old Jul 31, 2006 | 05:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
The neutral safety switch is located on the outside of the tranny underneath, so you won't need to take the shifter cover off to get to it.
