1968 Battery Apron
Old Jul 31, 2006 | 08:29 PM
Shifty101Easy's Avatar
Shifty101Easy
Default 1968 Battery Apron
does the battery apron bolt in on a 1968???
Old Jul 31, 2006 | 09:17 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 1968 Battery Apron
No
Old Jul 31, 2006 | 10:41 PM
Cogtx's Avatar
Cogtx
ORIGINAL: Shifty101Easy
My 67 coupe I6 has bolts on the battery apron area..see picture....I recently purchase a replacement piece for this and is doesn't have any bolt holes and has to be welded...
[IMG]local://upfiles/19071/A9D196395B2F4FED904659CB6E4924FF.jpg[/IMG]
Old Jul 31, 2006 | 11:00 PM
Shifty101Easy
yeah my 68 has that too...which is why i was wondering if its supposed to be easy replacement....as u all know, battery acid takes it toll over time....i got some surface rust there.
Old Aug 1, 2006 | 12:45 AM
428coupe's Avatar
428coupe
Those 3 bolts hold on the outer shock towers, the battery apron is welded in
Old Aug 1, 2006 | 01:57 AM
Shifty101Easy
oh i see.
Old Aug 1, 2006 | 01:21 PM
coda618's Avatar
coda618
Removing this panel is a pain. Lots of spot welds to be drilled out. Also, if youu dont rosette weld the new one in it will look crappy. I had rot under my battery, but the rest of the panel was good. I just cut a patch panel out of a sheet of steel and cut out the rusted area using the patch as a template and then seem welded the patch. Came out excellent and no drilling spot welds. If the damage is more extensive, you may consider buyiong a replacement panel and cutting just enough of it to repair your panel by seam welding.
Good luck.
Old Aug 1, 2006 | 04:27 PM
Shifty101Easy
yeah, its just surface rust so i could always sand it down probably....just figured it would be easier since those panels are cheap.
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
