Dash Repaint
Old Aug 11, 2006 | 11:02 PM
mustang652's Avatar
mustang652
Default Dash Repaint
While waiting on parts to complete the upgrades on the new head, I decided to go on with the dash and interior repaint. Can't figure out how to remove the light switch from the dash. I got the bezel loose, but I'm stuck at that point. There isn't an allen screw like on the wiper switch and I don't see anything that would release the **** or the shaft. Am I just better off to reassemble and tape off the **** and bezel.
Old Aug 11, 2006 | 11:10 PM
tylerdru's Avatar
tylerdru
Default RE: Dash Repaint
I am doing just that right now. I just taped all of the ***** off. When stripping the dash I reccomend that you use paintstripper and then sand off the remainder to bare metal.
Old Aug 11, 2006 | 11:17 PM
6788notch's Avatar
6788notch
There is a little button on the assembly in behind mine (on the other side of the dash where the wires hook up) you have to press it in with the **** all the way out then pull it out...it is on the right hand side on mine.
Darcy
Edit **I assume you mean the headlight switch**
Old Aug 11, 2006 | 11:28 PM
mustang652's Avatar
mustang652
Thanks to both of you. Did the tape off, strip and sand the first time I redid the dash 16 - 17 years ago. Just wanted to try to do a better job this time buy removing as much as I could. I'll look to see if I can find the release and should I fail at that I'll drop back 5 and do the tape routine again. Thanks again.
Old Aug 11, 2006 | 11:52 PM
6788notch's Avatar
6788notch
Maybe this picture will help you find it ....I had a hard time with the sucker!!
[IMG]local://upfiles/44050/C8F330521F284D96BDC5A61ED078C6A9.jpg[/IMG]
Old Aug 12, 2006 | 12:06 AM
mustang652's Avatar
mustang652
6788notch,
That was the trick, just ran out to the garage and rotated switch until I saw what your picture indicated. Immediate sucess. Many thanks.
mustang652
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
breaking
Oct 2, 2015 01:27 PM
GLOCKer
Sep 28, 2015 07:36 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
