speedo problem
Old Aug 15, 2006 | 12:58 AM
65Pony's Avatar
65Pony
Default speedo problem
when im driveing in my 65 the stock speedometer it has gets to about 10 MPH and any faster it will start doing this strange clicking noice and it will "bounce" up to a much higher speed and back down to the speed im going at, what can cause something like that?
Old Aug 15, 2006 | 01:02 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: speedo problem
Either the cable is going bad (most likely) or the speedo itself is going bad (less likely, but it happens). Disconnect the speedo cable from the back of the speedo and you'll be able to pull out the cable...but it's likely to be in two pieces if it's in too bad of shape. New ones are as close as your local auto store.
Old Aug 15, 2006 | 01:05 AM
19stang66's Avatar
19stang66
Mine does the same thing, well actually it just sit at like 190mph. This is after replacing the cable and housing too and I am on my second speedometer. I am going to lube up the new cable with some lithium grease and see if that works.
Old Aug 15, 2006 | 01:10 AM
Colorado_Mustang
If it's wound fully clockwise, that's a big problem. If it's going counter-clockwise, you have a problem with the gears being cut the wrong direction.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
