VIN
OK
Picked up my 69 fb
Worse then I hoped for but better then I feared
quesiton ...where the frikken hell is the vin located
I ll give the recap of the 10 hr drive in 3 gear later
Basically the clutch is ****ed, it dont grip, then it gets stuck and after a few secs comes poping back with a bang, the pedal sticks to the floor and then it snaps back.
It has a hurst stick protruding from the gear box, so I asume its a after marked installment of a "quick" shifter from hurst, its real tight...
But I aint got no 4 gear, its just like its not there, pull the stick back and its like nutral.
Any ideas other then sell the car, rip out and replace clutch plate and gear box
And
Id like a link to somewhere I could find some good 500+ handeling clutch systems and gear box
Erik
Picked up my 69 fb
And
Erik
Sounds like the clutch is way out of adjustment. It may be linkage causing all the problems you describe. Adjust it correctly and take it for a drive. I doubt it's any kind of a quick shifter, probably just a factory style Hurst shifter.
Wait. Scratch all that. I'll give you $100 to take this POS off your hands...
ORIGINAL: serdrogon
OK
Picked up my 69 fb
And
Erik
OK
Picked up my 69 fb
And
Erik
ORIGINAL: Soaring
Look on the dash, look on the door, and look on the inner fender.
Thx. will do
Drunk as a scunk atm so its gonna be tomorrow tho
Gonna take a ****load of pictures and post`em aswell.
Thx Soaring
Ok here goes
Same number on dash/window as the door so I didnt bother taking off the fender.
9T02L201501
second set of numbers on the door is
63 A T 2A 192(or a 19Z) B2 6 1
Any info on that and if so where did you find it please
Erik
9T02L201501
Erik
From those numbers, here is how it decodes.
Year: 9 1969
Plant: T Metuchen, NJ
Body Series: 02 SportsRoof
Engine: L 250 1v I6
Unit: Z01501 Z01501
Miscellaneous Vehicle Data
Body: 63A SportsRoof, Standard Interior
Color: T Candyapple Red
Trim: 2A Black Vinyl and Black Kiwi Vinyl, Standard Interior
Date: 192
D.S.O: B2 Eastern Canada
Axle: 6 3.00:1, Conventional
Trans: 1 3-Speed Manual
Year: 9 1969
Engine: L 250 1v I6
Unit: Z01501 Z01501
Date: 192
hmm. so its supposed to be a
250 ci engine and a standard interior.
but it has a 390 with a 4 speed manual, and deluxe interior.
its black colour outside and inside
looks like I might buy a crate engine if its not a original 390 in it.
if its not a "real" 390 car I might just go crate
Thx Soaring
Erik
Thx Soaring
Erik
