390 Engine Running Hot...What's Normal?
Old Aug 21, 2006 | 03:19 PM
Code_S_390's Avatar
Code_S_390
Default 390 Engine Running Hot...What's Normal?
I've been meaning to ask this question for a week and had a few mins on the computer now so I thought I'd throw it out...
How hot, at what temp, does your 390/big block run?
I'm at about 210 degrees.
- 88 degree day
- Stock engine with stock radiator
- A/C on full
This seems hot to me. However, I don't really want to loose my original radiator to an after-market product.
Any suggestions???
Lee
Old Aug 21, 2006 | 03:21 PM
Twister's Avatar
Twister
Default RE: 390 Engine Running Hot...What's Normal?
ORIGINAL: Code_S_390
- 88 degree day
- A/C on full
Any suggestions???
Lee
Lee, are you sure that it is a big block radiator? I would look at a 4 core, 210 is a little hot, I would want to see it lower, about 190-200
Old Aug 21, 2006 | 04:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that's too hot. If you don't want to lose the original radiator, take it to a rad shop and have then rod it. After all these years, it most likely is clogged with massive amounts of calcium and other crud.
Old Aug 21, 2006 | 05:47 PM
Code_S_390's Avatar
Code_S_390
Yep, it's original to the car (S-code with A/C).
However, having it rodded or recored is a great idea, I hadn't thought of that...[sm=goodidea.gif]
Also, I guess the first thing will be to have it back-flushed and see if that will help.
Thanks
Lee
Old Aug 21, 2006 | 06:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
I wouldn't back flush it. You might knock off some crap that will get hung in your block. Just take the old girl off and take it to a rad shop.
Old Aug 21, 2006 | 06:03 PM
Twister's Avatar
Twister
instead of rodding it, I would simply re-core it
Old Aug 21, 2006 | 06:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
Not sure just how much of the original radiator he wants to keep. Don't you lose most of it with recoring? I am certainly no rad expert.
Old Aug 21, 2006 | 06:47 PM
Twister's Avatar
Twister
the tanks are the important part, they have the date stamps.
Old Aug 21, 2006 | 06:55 PM
JBradley500's Avatar
JBradley500
I know that circle track engines are at prime running temperature when they reach 206 deg F.
Old Aug 21, 2006 | 09:34 PM
Colorado_Mustang's Avatar
Colorado_Mustang
210 isn't too hot if it sits there. I have a 196* thermo in my 390 and it sits between 205 and 215 depending on the wind direction. If you're worried, drop in a 180* thermstat.
