66 Mustang Fuel Gauge ??
Old Aug 23, 2006 | 08:31 PM
ronzara's Avatar
ronzara
Default 66 Mustang Fuel Gauge ??
Hello,
I resently bought a '66 Mustang with a nonworking gas gauge> it read "E" all the time. I pulled the Gauge pod and ran a continuity check on the fuel gauge. NO CONTINUITY> So I bought another gauge....put it in and wiring it up. When I turn the key on, the gauge shoots straight to FULL... the tank is nearly Empty...[:@]
I pulled the wire on the sending unit, thinking it may be getting grounded out somewhere, but the gauge still shoots straight to FULL.
I put a meter on the wires that connect to the fuel gauge ( NEG to BLACK/GREEN WIRE, POS to YELLOW/WHITE wire) and it pulses to the negative side of the scale,.... by "pulses" I mean it bounces as though it were connected to a turn signal flasher.....[&:]
If I swap the meter wires I get a pulse that goes from 0v- 12v-0v-12v...etc
I am wonder what the problem might be,.... INSTRUMENT CONSTANT VOLTAGE REGULATOR is bad???
I havent checked it yet. Any tips and trouble shooting this problem would be appreciated.
HELP??!?! thanks!
RON
Old Aug 23, 2006 | 08:34 PM
Twister's Avatar
Twister
Default RE: 66 Mustang Fuel Gauge ??
the sending unit needs to be adjusted...just bend it a little
Old Aug 23, 2006 | 08:51 PM
ronzara's Avatar
ronzara
The gauge is doing this with the sending unit DISCONNECTED also,... would that make a difference???
thanks
Old Aug 23, 2006 | 08:58 PM
Twister's Avatar
Twister
did you remove the gauge from the instrament cluster? it might be grounding to the metal gauge holder...
Old Aug 23, 2006 | 09:01 PM
ronzara's Avatar
ronzara
no, I didn't,... good suggestion, I will try it......... hold on.
Old Aug 23, 2006 | 09:32 PM
ronzara's Avatar
ronzara
Well,
The gauge was not grounding on the holder, although I do need a new voltage regulator now,... I saw it glowing red and smoking,... I don't think I should've loosed up the gauge holder posts and turned the key on.......[>:]
Ron
Old Aug 23, 2006 | 10:13 PM
Twister's Avatar
Twister
are the insulators on the posts?
Old Aug 24, 2006 | 12:50 AM
ronzara's Avatar
ronzara
there is a tab with 2 holes that goes across the poles that the 2 nuts go down on, I would assume this is just a hold down strap????
There is nothing I recognize as insulators. Are they rubber or what....and where exactly are they??
That could be the problem,... please advise, thanks!!
Ron
Old Aug 24, 2006 | 12:51 AM
Twister's Avatar
Twister
it is the tab
Old Aug 24, 2006 | 04:57 AM
ronzara's Avatar
ronzara
humm, well then, yes, it is on there..... I am going to check the wiring tomorrow to see if there are any breaks in it from the sender to the gauge. Also check the ground that attaches with the wiper motor wires,....
