Removing Speedo Needle
Old Aug 23, 2006 | 10:29 PM
Toddman0025's Avatar
Toddman0025
Default Removing Speedo Needle
I got some gauge overlays but can't figure out how to remove the speedometer needle in order to install them.
It's got a pin riveted into the needle assembly that runs through the gauge face and into the gearing, just pull outward?
Old Aug 23, 2006 | 11:11 PM
19stang66's Avatar
19stang66
Default RE: Removing Speedo Needle
is that a stock speedo for your car? i like the running pony. On my 66 speedo all i did was pull it off. it never did stay on though after that. [&:]
Old Aug 23, 2006 | 11:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
The needles just pry off, but be extremely careful not to bend it, otherwise you will never get it straight again.
Old Aug 23, 2006 | 11:57 PM
Scott H.'s Avatar
Scott H.
I pinch-roll my thumb and forefinger under the needle 180 degrees apart which applies even upwards pressure for a straight pull. Make sure not to twist the needle at all, or it won't register correctly. Install is exact oposite pressure with the same two fingers in the same two spots rolling away from the needle.
Old Aug 24, 2006 | 12:31 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, what she said.
Old Aug 24, 2006 | 01:41 AM
Toddman0025
got it thanks
Old Aug 24, 2006 | 06:08 AM
slickman's Avatar
slickman
Just get one of these and move to the dark side
[IMG]local://upfiles/26659/832204F85746440BB3633D49869E080E.jpg[/IMG]
Toddman0025
Hah I wish - haven't found them for a '69 yet
Old Aug 24, 2006 | 06:13 AM
slickman's Avatar
slickman
You mean one of these?
ORIGINAL: Toddman0025
[IMG]local://upfiles/26659/DF48D592E41E4A1FAE908F37A37D11FD.jpg[/IMG]
Dakota Digital
Old Aug 26, 2006 | 03:43 AM
Toddman0025
WOW those are nice!
My pocket can only afford these for now [:'(]
