Project Update as I go
Old Aug 27, 2006 | 07:44 PM
wil33562's Avatar
wil33562
Default Project Update as I go
I'll use this thread to update my Mustang project until I'm through with it (might take several years!!)
I purchased my Mustang on May 22, 2006. I believe it is a 65, but that's a whole other story! See my previous post about it!
I haven't really done a lot to it since I purchased it, other than scraping off all of the tint. The past two weekends I have started stripping the paint. Last weekend (8-19-06) I started on the trunk lid and finished it with a grey primer.
This weekend (8-26-06) I started stripping the LH rear quarter panel. I used Aircraft stripper, a orbital sander, and lots of elbow grease. Aircraft stripper is a man's best friend when it comes to stripping paint.
Anyway, here are the pics from the day I bought it til now:
Pic 1: May 22 the day I purchased it.
Pic 2: May 22 the tail end of it.
Pic 3: Aug 26 trunk already stripped and primed (will eventually need a new trunk lid due to rust in RH lower corner)
Pic 4: Aug 26 LH rear portion of quater panel stripped down and sanded.
Pic 5: Aug 26 RUST (OH NO!) maybe this is the the worst of it!! I doubt it!
[IMG]local://upfiles/35640/3A16DE6227D44555B37FED67CAF686EB.jpg[/IMG]
[IMG]local://upfiles/35640/247FA7B22F614A1A88DB8738F956FFBB.jpg[/IMG]
[IMG]local://upfiles/35640/D766BA56DE19492FBD9647DBC9D091E3.jpg[/IMG]
[IMG]local://upfiles/35640/5B2CC14BADBD48179D18356DA38A513E.jpg[/IMG]
[IMG]local://upfiles/35640/6E24AD4283F4416F86F59F8655108650.jpg[/IMG]
Old Aug 27, 2006 | 07:47 PM
wil33562's Avatar
wil33562
Default RE: Project Update as I go
Pic 1: Aicraft stripper painted on. Let it set for 15 min
Pic 2: Aircraft stripper in action: nice bubbles!
Pic 3: first round of stripping paint
Pic 4: Another layer of aircraft stripper applied and second round of stripping done.
Pic 5: After 20 minutes of sanding
[IMG]local://upfiles/35640/5FEB92C3F8C8406FA59CE4364E14240E.jpg[/IMG]
[IMG]local://upfiles/35640/699829EC046749B49859FFD38E3F9F33.jpg[/IMG]
[IMG]local://upfiles/35640/19AC258ED08741ED9497C1B788D21601.jpg[/IMG]
[IMG]local://upfiles/35640/F3439187AD294335B89AD5B00D9D606E.jpg[/IMG]
[IMG]local://upfiles/35640/9A33EFE27AEF4ED1A90EDB0C9CB2653F.jpg[/IMG]
Old Aug 27, 2006 | 07:50 PM
wil33562's Avatar
wil33562
Pic 1: After another 10 minutes of sanding the entire quarter panel is down to metal other then around the side ornament. It took a total of about 1.5 hours to strip the area between the LH door and mid ways over the wheel well.
Question: How does the side ornament come off?
Thanks,
Kris
[IMG]local://upfiles/35640/129BB69B941343B5BDC8A6E6E399E35C.jpg[/IMG]
Old Aug 27, 2006 | 08:02 PM
THUMPIN455's Avatar
THUMPIN455
They bolt on from the backside.. remove the rear seat, then the kick panel next to the seat and with enough light you should be able to see the nuts.
Looks like you are doin a fine job...
Fun isnt it? Just wait, it gets better... lol
Old Aug 27, 2006 | 08:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you want to keep those wheels for later, you best take them off and put the car on stands. They will definitely get stuff on them.
Old Aug 27, 2006 | 08:15 PM
wil33562's Avatar
wil33562
Yes, it is a lot of fun minus the blisters!
Right now, I'm working about 6 hours each weekend on it and 2 during the week. I figure it will take me a total of about 100-120 hours to get all of the panels stripped and primed. So it should be ready for body work in about 3-4 months.
I'm going to replace the trunk lid with a used one in better condition. The LH and RH rear portion of the quarter panels will have to be patched. Both doors have some rust holes in them and I'm trying to figure out if it will be cheaper to order new skins or patch the existing panels. Also, some PO put a nice hole in the top of the LH quarter panel for an antanea, so that will have to be patched too.
How much do you think it will cost to patch both rear portions of the quarter panels and then a 1.5" hole on top of the rear quarter panel?
Kris
Old Aug 27, 2006 | 08:17 PM
Sean W.'s Avatar
Sean W.
where do you get aircraft stripper? and how much is it, and for the price how much do you get and how far will it go?
Old Aug 27, 2006 | 08:25 PM
wil33562's Avatar
wil33562
You can get aircraft stipper at WalMart in the automotive section. It is about $7.50 for a quart of it. So far I have used it on the trunk and quarter panel and still have about 1/3 left.
I figure it will take about 1 gallon to do the entire car.
Old Aug 27, 2006 | 08:27 PM
Sean W.'s Avatar
Sean W.
is it harmfull to your skin? do you have to wear gloves? can yuo explain the process of striping paint with teh air craft stripper for me please.
Old Aug 27, 2006 | 08:28 PM
THUMPIN455's Avatar
THUMPIN455
It took me 2 gallons of stripper to do a 71 Firebird to bare metal. It had a bunch of paint on it.
How much it costs to fix metal is directly related to how much you can do on your own.. Less you can do costs you more.
