Removing rear shocks?
Old Aug 30, 2006 | 12:29 AM
MakiMaki's Avatar
MakiMaki
Default Removing rear shocks?
Hello Everyone,
Im in the middle of putting new shocks into my 65 coupe, but ran into a snag.
The rear shocks..... you know where there located, its behind the back seat and yada yada, basically i cant figure out how im supposed to hold the shock stud and still be able to put a wrench on the nut to remove it. How have you all done this, is there a tool im not familiar with, please advise.
Thanks to all.
Old Aug 30, 2006 | 12:57 AM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: Removing rear shocks?
I think that mine had a notched part on the top so I could hold it with a wrench. Maybe you should think about grinding you one off on yours.
Old Aug 30, 2006 | 01:07 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
have some one hold them with a pair of vise grips from under the car or get the actual shock tool from auto zone they have it for a loan a tool i beileve
Old Aug 30, 2006 | 01:20 AM
MakiMaki's Avatar
MakiMaki
Theres a shock tool?
Ill go get it.
I thought about having someone hold it, but cant make that happen. Does the shock tool actually hold the shock and allow me the ease of just using a socket on the nuts? Because I see no way of someone holding the stud and turning the nut in that space. The bottom was easier because the access, but theres very limited access on top.
Thank you very much.
Old Aug 30, 2006 | 01:27 AM
67Stang68's Avatar
67Stang68
I went the vise grip route myself, I was too lazy and cheap to get the tool.
Old Aug 30, 2006 | 02:06 AM
MakiMaki's Avatar
MakiMaki
Just got back....
They had no idea what i was talking about. Gonna try to grip it. There must be a better way. Peace to all.
Old Aug 30, 2006 | 02:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67Stang68
I don't have vice grips big enoungh to hold the outside part, so I used a pipe wrench and jammed it in. That worked for me.
Old Aug 30, 2006 | 02:12 AM
MakiMaki's Avatar
MakiMaki
Yeah same for me.... Cant grip it, the shock cover is too big, pipe wrench is what im thinking too. Still am so surprised that this is how. Anyone know the name of that tool?
Peace.
Old Aug 30, 2006 | 03:55 AM
baddog671's Avatar
baddog671
I squeezed a set of vise grips onto the shock's shaft so when I turned it up top with a rachet, it would turn and hit the undercarraige. I didnt have a second pair of hands to help, but when it hit, it wasnt spinning anymore.
Old Aug 30, 2006 | 05:34 AM
MakiMaki's Avatar
MakiMaki
Just got back from the test drive.
The pipe wrench did it. I couldnt vice the shaft because it wasnt exposed (covered), but all good now. Thank you all very much.
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Doogie65
Sep 6, 2015 02:55 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
