what is this?
Old Aug 30, 2006 | 06:35 PM
BillyBobJoe's Avatar
BillyBobJoe
Default what is this?
im in the process of re-wiring my dash and as i pulled the old dash out of the parts car a clear/white vacumn canister came with it. There are two red wires attached to it too. Anyone know what this is? It's right behind the ignition switch. It had a small cable atached to the steering column. Thanks.
Old Aug 30, 2006 | 07:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: what is this?
possibly a tilt away steering setup
Old Aug 30, 2006 | 11:35 PM
67Sally's Avatar
67Sally
Turn Signal? I have no idea, can you post a pic?
Old Aug 31, 2006 | 12:00 AM
BillyBobJoe
ok, sorry i couldnt get a pic up earlier, but now im back home. i have no idea why it would be related to the turn signals or the tilt column, but this is the pic. There is a hole for a vacumn hose on the back of the smaller black cylinder.
[IMG]local://upfiles/16555/C2F7F963C215497883F9078C86F325DA.jpg[/IMG]
Old Aug 31, 2006 | 12:12 AM
6mustang6's Avatar
6mustang6
yep, maybe tilt away steering. DOes your car have tilt wheel? If so, you have have tilt away steering. What it does is, move the steering wheel away, when you open the door. Do you have two door switches or just one?
Old Aug 31, 2006 | 01:24 AM
BillyBobJoe
ya, i have the tilt away steering. and ya, two switches. I didnt know thats how it worked though. thanks.
Old Aug 31, 2006 | 03:58 AM
Brandontyler65
I ♥ Acer
ya my 67 had the everything for it cept the actual column cause i saw everything it needed in the cept my column so i thing it was replaced
Old Aug 31, 2006 | 04:01 AM
Twister's Avatar
Twister
again, it is a tilt-a-way
