AW SH!T (pitman arm)
Old Sep 2, 2006 | 08:40 PM
Gun Jam's Avatar
Gun Jam
Default RE: AW **** (pitman arm)
Its really easy to get back on I was worried too because i thought I would never get it to line back up but its keyed in four places so its pretty easy to line back up if your off by one key its going to be 90 degrees off so its easy to see that its on the wrong key. (just remember where it was when you took it off)
1 and 1/4 sounds close to the size but I dont remeber
Gun
Old Sep 2, 2006 | 09:05 PM
Toddman0025's Avatar
Toddman0025
do you think a gear puller would work?
none of the auto stores have pitman pullers around here...
Old Sep 2, 2006 | 10:10 PM
Scott H.'s Avatar
Scott H.
You don't hit the ball stud, you hit the side of the pitman arm where the ball stud goes through. This is a rather gross analogy but... it's kind of like squeezing a zit.
Sorry, but I couldn't think of anything better...and now I'm getting nausious. [&:]
Here is about as artistic as I can get. The "O" is the ball stud Hold the one sledge where I have the ">" symbol, and whack it good where the "<" symbol is. It might take a few raps, but it will work. Because the hole is tapered you force it loose this way.
O
_/ \_
>( _ _ )<
l l
HTH,
Scott
Old Sep 2, 2006 | 10:35 PM
Gun Jam's Avatar
Gun Jam
Its defiantly worth a shot (just don’t miss) especially if you don’t have the puller handy
I used a gear puller on mine as long as it makes good contact on either side of the pitman arm and fits square then its okay
Gun
Old Sep 2, 2006 | 10:53 PM
Toddman0025
ok thanks guys - i picked up a sledge and gear puller so we'll see which one prevails
Old Sep 3, 2006 | 03:08 AM
Scott H.'s Avatar
Scott H.
You really want two sledge hammers not just one. One will do it, but you are going to work harder and shock the crap out of your steer box (possibly damaging it).
Old Sep 3, 2006 | 09:17 PM
Toddman0025
Well guys I'm stumped - beat the crap out of it with two sledge hammers with no progress and couldn't get the gear puller to grip securely enough...
I'm thinking maybe just cut the ball stud below the pitman arm and then drill up through it until the threaded portion falls out...
Old Sep 3, 2006 | 09:37 PM
Gun Jam's Avatar
Gun Jam
why would the gear puller not hold on? where the jaws too far apart?
I would suggest finding a better suited puller, Look for a bearing puller instead they tend to have closer set jaws and the pitman arm collar (where you place the jaws) is about the size of some common bearing races
There is a chance you might have to drill a shallow depression in the output shaft of the gear box to keep the puller from wandering. I didnt have to do that on mine but my puller probably had closer jaws and only two of them not three. look for that 2 jaw bearing puller.
Gun
Old Sep 4, 2006 | 12:41 AM
dcohen's Avatar
dcohen
be careful with that puller, i was tryin to take the pitman arm off my 66 coupe with one and it slipped off, damn near broke my hand
just thought i'd warn ya
guitarman376
Oct 11, 2015 01:47 AM
UrS4
Oct 3, 2015 06:23 AM
UrS4
Sep 30, 2015 10:13 AM
03blackwidow
Sep 20, 2015 02:36 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
