I NEED HELP NOW!!!!!
Old Sep 2, 2006 | 11:00 PM
ADRIAN1's Avatar
ADRIAN1
Default I NEED HELP NOW!!!!!
I JUST CHANGED THE WATER PUMP BUT I CANT REMEMBER HOW TO MOUNT THE ALTERNATOR BRACKET BACK ON. PLEASE POST SOME PICS! QUICK!!!!!!!!!THANK YOU!
Old Sep 2, 2006 | 11:15 PM
Sean W.'s Avatar
Sean W.
Default RE: I NEED HELP NOW!!!!!
that alternator bracket can only go on one way, at least on the 68' just fiddel with it till it goes on.
Old Sep 2, 2006 | 11:19 PM
ADRIAN1's Avatar
ADRIAN1
I NEED PICS!!!!!
Old Sep 2, 2006 | 11:24 PM
Sean W.'s Avatar
Sean W.
did you try to fiddel with it or did you just look at it and say i dont remember how to do this, and came crying to us for help.... if so, get out there and try to play with it, im sure you will get it to work...
Old Sep 2, 2006 | 11:25 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
sorry i dont have pics but put the big bolt back thru the alternator/ bracket and swing the other end towards the water pump and line up the two holes on that side and the adjusting arm goes under the upper bracket in the next lowest hole i beileve
Old Sep 3, 2006 | 01:10 AM
hwy1strat's Avatar
hwy1strat
It only goes on one way, just fiddle with it like sean w. said
Old Sep 3, 2006 | 04:26 AM
atomsk680's Avatar
atomsk680
you need a sticky note near your screen that says "dont forget to turn off your capslock button."
Old Sep 3, 2006 | 05:19 AM
Sean W.'s Avatar
Sean W.
[sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif]
Old Sep 3, 2006 | 10:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
Count from the botton front bolt hole three holes and that will be the hole for the bracket. If you use any other hole, the alternator will hit the bracket when you try to tighten it.
Old Sep 3, 2006 | 01:41 PM
EmperorOfChicken's Avatar
EmperorOfChicken
CAPS LOCK, CRUISE CONTROL FOR AWESOMEEEEEEEE!!!
