Can this spark plug wire be saved ?
Old Sep 6, 2006 | 08:49 PM
Toddman0025's Avatar
Toddman0025
Default Can this spark plug wire be saved ?
I just bought these #$@%ing things and already screwed one up - can these be "stripped" and reconnected like normal electrical wires or do I need to buy an entire new set?
(If you're wondering what happened the metal part stayed on the plug when I pulled off the boot, the wire completely disconnected)
Old Sep 6, 2006 | 08:53 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Can this spark plug wire be saved ?
Yes it can be saved.
You shouldn't need to restrip it unless the core wire is messed up. Take a pair of needle nose pliers and pry into the connector a little bit to open it up so you can properly recrimp it over the wire and shielding. The core of the wire is supposed to stick out like that since it's folded back over wire casing before getting crimped in the connector.
Old Sep 6, 2006 | 08:55 PM
randy78045's Avatar
randy78045
Buy a quality new set an call it a day.... [:-]
Old Sep 6, 2006 | 08:58 PM
Toddman0025
ok if i'm looking into the wire there's red outer shell, some kind of yellow stuff, then white fiberglass-looking stuff, and then a thin metal wire (almost like metal sewing thread). What part gets crimped into the metal connector?
I'm thinking something needs to be exposed and touching the metal connector but I could be wrong?
Old Sep 6, 2006 | 08:59 PM
Toddman0025
ORIGINAL: randy78045
These cost $60! No way I'm giving up that easy!
Old Sep 6, 2006 | 09:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
http://www.automedia.com/Custom/Fit/...cr20050501cw/1
this should help
And since when is Mallory Wires not a quality set!?!?
[IMG]local://upfiles/13248/4BE4654E8AB74F7C9041AF8295B145F7.jpg[/IMG]
Old Sep 6, 2006 | 09:03 PM
randy78045's Avatar
randy78045
ORIGINAL: Toddman0025
For $60 you shouldnt be having these problems...
Soaring's Avatar
Soaring
I ♥ Acer
If there is any one thing I learned as a young wrench turner, it was to buy quality spark plug wires. Yeah, you can re-crimp that thing, but you will probably have a static radio and get about half the juice to the plug that you need. See if there is a black thread inside that needs to crimp over so that good contact is made with the metal.
Old Sep 6, 2006 | 09:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That bit of wire (3/8" - 1/2") that is exposed from the jacket is what gets folded back over the shielding. THen the metal crimp goes over both the wire and the jacket. The Crimp is actually crimped over the jacket with the wire sandwiched between it and the crimp.
Old Sep 6, 2006 | 09:08 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Soaring
and thats not true either. Geez.... Do you honestly feel that because a recrimp is needed he's not going to get the juice that is needed to the plug? Recrimping doesn't change anything unless the core was messed up. In that case you simple strip the jacket back a bit further back and recrimp with a 'new' piece of wire. The only difference is a machine crimp vs a human crimp. So long as he takes care to make sure the connection is good, he loses/sacrifices nothing.
Edit: If your theory were true then I guess all the stereo installers are just SOL since they will never get full power out of their amps or stereos because they had to crimp it themselves....
