spiderweb of wires
Old Sep 8, 2006 | 05:22 PM
atomsk680's Avatar
atomsk680
Default spiderweb of wires
ok, i have this red switch under my dash, its not factory and i have no idea what it could be
it goes under the dash through the firewall and comes up around here and goes up to this web of wires, some connected some not.
anyone else seen one of these before?
Old Sep 8, 2006 | 05:29 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: spiderweb of wires
Well...have you tried to figure out exactly where that particular wire goes? Could be a kill switch (though pretty stupid to make it that obvious), could be for fog lights, could be for a number of things. Trace the wire see where it leads you. Hopefully the color of the wire is the same throughout its length to make it easier to trace.
Old Sep 8, 2006 | 05:49 PM
atomsk680's Avatar
atomsk680
im positive its not my grille lights, the problem is, all these wires, are th same exact color. some plugged some unplugged. there are 2 going to my ignition though. i think it is a kill switch, not the best place for one though. im gunna try and see if connecting some of these loose ends has anything to do with my car not starting (other then it being well over a month without start.
Old Sep 8, 2006 | 05:57 PM
Derf00's Avatar
Derf00
Gentleman's Relish
well, if it was running before and now it's not and the car has just been sitting. I find it difficult to say that wires are the cause. Have you tried flipping the switch???
I wonder what this does!??!
Old Sep 8, 2006 | 06:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Derf00
Yeah, I was going to say. "flip the switch dummy, and see what happens." But, you beat me to it.
Old Sep 8, 2006 | 06:26 PM
atomsk680's Avatar
atomsk680
yea i have. one way i turn the key and nthing happens, another way i turn the key and the switch lights up, but still nothing happens
Old Sep 8, 2006 | 07:00 PM
Matt04roush's Avatar
Matt04roush
Have you tried the Horn? i had the samething on my 65
Old Sep 8, 2006 | 07:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: atomsk680
What do you mean by "one way?" If turning it to the left toward the accessory position, you may have a stereo accessory switch which activates a power amp. Who knows? If it were mine, I would take the thing out and deactivate it.
Old Sep 8, 2006 | 07:26 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
ORIGINAL: atomsk680
oops sry, i meant when i turn the key, when i turn the key to start with the switch flipped to the left, nothing happens, when the switch is on the right, nothing happens But, the switch lights up.
its not my horn cause i dont have a horn, when they replaced my steering wheel they removed the horn.
Old Sep 8, 2006 | 11:40 PM
atomsk680's Avatar
atomsk680
i think im just gunna take it out
