Hooker Comps Vs Super comps
Old Sep 8, 2006 | 07:43 PM
palerider's Avatar
palerider
Default Hooker Comps Vs Super comps
Just talked to tech support line at Summitt they told me that with my engine set up being fairly mild (302, 600 holley, and performar manifold) I would be fine with regular comps and super comps would not give much more benefit, recommended just going with regular comps. I've decided on Hooker, ceramic but was not sure if super comps worth the extra $200 - any insights appreciated. thanks
Old Sep 8, 2006 | 10:17 PM
69mach1377's Avatar
69mach1377
Default RE: Hooker Comps Vs Super comps
Not worth it unless your engine is highly modded for power.
Old Sep 8, 2006 | 11:53 PM
middiepride's Avatar
middiepride
unless you really need that little extra power they offer(i.e. drag racing) dont spend it. you wont even get the seat of the pants feel either.
Old Sep 9, 2006 | 03:54 AM
2bav8's Avatar
2bav8
Super Comps also have a lot LESS ground clearance.
Not a big deal if you are a drag racer, but if handling is important super comps won't provide enough clearance.
I am currently in the process of replacing my super comps because of this issue.
#8 tube cracked after one too many speed bumps, sigh.
Old Sep 9, 2006 | 05:19 AM
65mojoe's Avatar
65mojoe
you won't feel a difference between the two and if im not mistaken I think the supercomps are routed slightly different on the driver side and it's supposed to make things even more of a biatch to install (like putting in headers isn't already a headache).
Old Sep 9, 2006 | 09:42 PM
2bav8's Avatar
2bav8
This is true too, the super comps are much more difficult to install on the drivers side!
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
Luke9222
Sep 4, 2015 06:46 AM
