misfiring
Old Sep 13, 2006 | 03:37 PM
stang4lyfe's Avatar
stang4lyfe
Default misfiring
k so about two days ago i was driving home and was going up a hill, not too steep but probably about a 10% grade and i noticed my car misfiring. so the next day i switched out the plugs which had quite a bit of high speed glazing (i dont speed i swear) and put the car back togeather. well now its still misfiring when ever some sort of load is put on the engine. if i put the gas ne more than say 50% to the floor i misses horribly and i get a nice little gas smell. the wires are fine, cap and rotor are fine (changed those out bout month ago). the distributor was change to electronic bout 2 years ago. the only thing i could think of is maybe the coil? im guessing its still original so im wondering if that is the culprit.
-mike
Old Sep 13, 2006 | 03:58 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: misfiring
could be could also be a carb adjument also i had the same problem try checking your fuel pump it might be going on you
Old Sep 13, 2006 | 04:13 PM
stang4lyfe's Avatar
stang4lyfe
i tune the carb everytime a get home from school for the summer so i doubt its that i and also have a gauge on the fuel line to the carb and it reads bout 6-6 1/2 psi constantly, same if i accelerate it as well
Old Sep 13, 2006 | 04:19 PM
Brandontyler65
I ♥ Acer
what kind of carb could be wrong/bad power valve
Old Sep 13, 2006 | 05:22 PM
stang4lyfe's Avatar
stang4lyfe
every engine part is original 'cept hooker headers. still got the old 2bbl motorcraft carb on their and never had a problem with it
Old Sep 13, 2006 | 05:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Try a new coil. Also, check the gas to make sure there isn't water in it.
Old Sep 13, 2006 | 11:51 PM
Silver Ponys's Avatar
Silver Ponys
Soaring has the right idea mine did the same thing once changed out everything i could think of turn out to be the coil
Old Sep 14, 2006 | 02:20 AM
stang4lyfe's Avatar
stang4lyfe
k small update. thought i take a cheap way and hope and changed the spark plug wires. changed those out and before i did it my fuel pressure gauge was bouncing all over the place and found that odd. but the worst thing just happened. changed out the spark plug wires and now im getting a thunking sound from what sounds like the end of my headers......backfire possibly?? but it doesnt sound loud enough, almost sounds like the quick thunk every less than 5 seconds
HELP!
Old Sep 14, 2006 | 06:05 PM
stang4lyfe's Avatar
stang4lyfe
weeee bit of help ne one?
Old Sep 14, 2006 | 06:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Are you damn sure you have the plug wires hooked up in the right firing order? Get out there and check it again.
