clutch linkage
Old Sep 14, 2006 | 01:33 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default clutch linkage
went to install my clutch linkage and the z bar wont go all the way back for me to stick the pushrod in there so i can get my clutch working[:@] i guess im gonna have to heat the header and bend the pipe so it wil clear anyone else run into this problem on there 284 4spd with tri-y combo? alos someone got pics where the return springs go so i can figure those out? top and bottom
Old Sep 14, 2006 | 01:36 AM
Twister's Avatar
Twister
Default RE: clutch linkage
are the engine mounts used?
Old Sep 14, 2006 | 01:38 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
nope there brand new 65 style mounts
Old Sep 14, 2006 | 01:54 AM
Twister's Avatar
Twister
odd... is the spacer on the right side?
Old Sep 14, 2006 | 01:55 AM
mustanglover66's Avatar
mustanglover66
return spring goes from the zbar to release lever I would take pics but its dark out and its late. I do have the same setup tri-y and toploader
Old Sep 14, 2006 | 02:01 AM
Twister's Avatar
Twister
I was also thinking...a K-Code Z-Bar might fit better
Old Sep 14, 2006 | 02:06 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
idk i think im gonna torch the hgeader and bend it down and a couple of inches?
valley firearms's Avatar
valley firearms
Pictures would be great. I test fitted my equalizer bar and it seems too long. Here's my dillema. I have the GT40P heads w/ shorty headers. I assume will have to use the adapter mount that bolts to the bellhousing.
Old Sep 14, 2006 | 02:23 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the frame side mount is adjustable loosen it up put the z bar in and push it back over and tighten it up
Old Sep 15, 2006 | 10:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well i got the clutch z bar stuffed hooked up i gotta reinstall the header i took a hammer and slightly dimpled the tube gonna see if that works. the clutch is not as stiff as people make them out to be?
