transmission cooler?
Old Sep 14, 2006 | 04:15 AM
ADRIAN1's Avatar
ADRIAN1
Default transmission cooler?
im in the process of deciding what radiator to get but, some say they are equipt w/ a tranny cooler and some are not. do i need a transmission cooler? if i get a radiator that is NOT equipt with a tranny cooler, where can i buy one and where do you guys mount them? please post pics of your set-ups and include if your radiator was equipt w/ it or you put a seperate one. THANKS!
Old Sep 14, 2006 | 04:31 AM
Twister's Avatar
Twister
Default RE: transmission cooler?
if you have an auto...you need a cooler!
Old Sep 14, 2006 | 04:45 AM
ADRIAN1's Avatar
ADRIAN1
i have an AUTO! ok well can you guys post pics/advice. THANKZ!!
Old Sep 14, 2006 | 07:50 AM
slickman's Avatar
slickman
If you wind up getting a alum radiator and don't plan on running it HARD, you don't need one..
Old Sep 14, 2006 | 09:21 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You will need a cooler, but it doesn't have to be built into the radiator. Many places make a stand alone transmission cooler that mounts in front of your tranny (anywhere with air flow). You can also get electric fan equipped tranny coolers.
Old Sep 14, 2006 | 10:48 PM
Shifty101Easy's Avatar
Shifty101Easy
what if you get an tranny cooler equipped radiator but have a manual transmission? just plug the holes and forget about it?
Old Sep 14, 2006 | 11:42 PM
Colorado_Mustang
Yep. Though you can put a tranny cooler on a manual tranny if you really wanted to.
ORIGINAL: Shifty101Easy
Old Sep 15, 2006 | 12:03 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, I have a 4 row with the tranny cooler holes in the bottom of it, and I just plugged it with two bolts. Works for me.
Old Sep 15, 2006 | 05:13 AM
65bluestang's Avatar
65bluestang
same with me and mine works just fine.
Old Sep 15, 2006 | 06:15 AM
Shifty101Easy
okay good because i just ordered an aluminum radiator with tranny holes but plan to switch to a 5 speed in the hopefully near future from my C4....
