wheel pops
Old Sep 17, 2006 | 01:22 PM
slick66stang's Avatar
slick66stang
Default wheel pops
since i put my original wheels back on everytime i make a turn i can hear a popping noise coming out of my right tire. i dont have the grease caps on so could that be a factor?
Old Sep 17, 2006 | 01:41 PM
randy78045's Avatar
randy78045
Default RE: wheel pops
Grease caps shouldnt be a factor.... [:-]
Are your bearings in good shape.... is your spindle nut (or whatever it's called) nice and snug against the bearing? just a couple thoughts... [:-]
Old Sep 17, 2006 | 01:54 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
jack up that side of the car and firmly grab the wheel at the top and the bottom and see where the play is coming from. also from side to side maybe a wheeel bearing might be a tie rod etc just basically look for something loose also not a good idea to not have the grease cap on there keep road grit out of the bearings
Old Sep 17, 2006 | 03:38 PM
slick66stang
everything is snug and new, nothing is loose. i think im going to repack my bearings and regrease everything.
Old Sep 17, 2006 | 03:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
DO NOT use a wrench on that nut that holds the bearing in. Finger tighten only until you can get the cotter key in.
Old Sep 17, 2006 | 05:49 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u have to use a rolling torque on wheel bearing (means u must spin the wheel while torquing) cant use a ratchet type torque wrench has to be a beam type
Old Sep 17, 2006 | 05:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
My torque wrench is my thumb and two fingers.
Old Sep 17, 2006 | 06:15 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u have to tighten more than the final torque to properly seat the bearing cant do that with ur two fingers glen then back it off and then torque again to the proper torque all while spinning th ewheel
Old Sep 17, 2006 | 06:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I guess with a new bearing, you are right. However, if you are only greasing the old bearing, using your thumb and two fingers is all you need. Just push on the wheel and wobble it while pushing on the bearing with the washer in place until it seats, then tighten with thumb and two fingers. Been doing it for many, many years and have never had a bearing burn out because it is too tight or any wheel wobble because it is too loose. Most of the time, shade tree mechanics make the mistake of getting them too tight, and the bearing burns out prematurally. You will also get what sounds like a popping sound if they are too tight, so that's why I said what I said.
Old Sep 17, 2006 | 07:17 PM
slick66stang
thanks everyone i finally got it fixed. the problem was two of my lugs on the front passenger side wasnt tight.
