starting problem behind coil
Old Sep 17, 2006 | 10:41 PM
juniorb_41's Avatar
juniorb_41
Default starting problem behind coil
my mustang stopped running in the middle of the road and wouldnt start up again. i have fuel so i assume there is an ignition problem. i checked and i took off the high intensity wire from the distributor and put it next to the heads and got no spark from the coil. how much voltage should i have on the + side of the coil and the -(negative) side of the coil. i have electronic ignition, so how could i check that as well, eventhough i think that shouldnt have much to do with it.battery is good, turns over.
Old Sep 17, 2006 | 10:43 PM
juniorb_41's Avatar
juniorb_41
Default RE: starting problem behind coil
also any way to just hot wire the coil so i would know it should work.
Old Sep 17, 2006 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
You should have up to 6 volts at the coil when you check it with a multi-meter and the engine is running. You could run a hot wire directly from the battery to the plus side of the coil to bypass the pink resistor wire.
Old Sep 17, 2006 | 11:15 PM
juniorb_41's Avatar
juniorb_41
if i did that wouldnt i have a full twelve volts, which is alot more than six. now i have around seven is that bad or acceptable?
Old Sep 17, 2006 | 11:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Up to twelve is acceptable.
Old Sep 17, 2006 | 11:24 PM
slickman's Avatar
slickman
Check you're electronics in the dizy and you should have 8 volts at the dizzy.. The ping resistor wire that feeds the coil drops it down from 12 volts to 8 volts.
ORIGINAL: juniorb_41
Old Sep 17, 2006 | 11:27 PM
juniorb_41's Avatar
juniorb_41
so i get seven at the + side of the coil and it says around 1.5 for the neagative side. than i dont get any spark out of coil, do i know coil is bad. how do i test coil as well.
Old Sep 17, 2006 | 11:33 PM
slickman's Avatar
slickman
If you have voltage at the coil then one of two things can be wrong. The coil is bad or the electronics in the distributor is bad. The coil is the cheapest replacement so, do that first.
Old Sep 17, 2006 | 11:34 PM
slickman's Avatar
slickman
Seeing he has an electronic distributor, you are correct...
ORIGINAL: Soaring
ShaneB26154
35
Mar 4, 2021 04:05 AM
Philhampton1
Aug 21, 2015 12:04 PM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
