Rust Question (see Pic)
Old Sep 18, 2006 | 07:32 PM
Mustangn's Avatar
Mustangn
Default Rust Question (see Pic)
How bad is this rust and how much will it cost to repair See Picture? This is a 1969 fastback
[IMG]local://upfiles/35309/E933C55E845445DB9775A9E6DFA9A9E5.jpg[/IMG]
Old Sep 18, 2006 | 07:38 PM
atomsk680's Avatar
atomsk680
Default RE: Rust Question (see Pic)
where?
Old Sep 18, 2006 | 07:42 PM
jarrettdad's Avatar
jarrettdad
Hell, looks rust free to me..... but then I may have a different perspective than you.....
Looks like no structural problem, just clean the entire area to see if it's any worse than that.
Old Sep 18, 2006 | 09:57 PM
Sean W.'s Avatar
Sean W.
i dont see any rust in that picture that you should be worried about...
Old Sep 18, 2006 | 10:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Just wire wheel the suspected areas , then prime and paint it.
Old Sep 18, 2006 | 10:37 PM
428coupe's Avatar
428coupe
I think I see the rust you are talking about. If indeed that is rust, it looks like a floor pan replacement may be in order.
[IMG]local://upfiles/40458/E009F57586344D42BB3377B191BA55A9.jpg[/IMG]
Old Sep 18, 2006 | 10:39 PM
THUMPIN455's Avatar
THUMPIN455
Looks like the floorpan is rotted a bit near the trans tunnel. I can point it out for the rest of you if you like How to fix that is easy, clean the entire area so there is only bare metal then you will find the extent of the rusted areas. Once you find out how much of the floor is gone, you can then get patches or replacement floors for it. Just on the surface it doesnt look like you will need an entire floor, just a patch or two. You can get those from the sheetmetal vendors everyone asks about ie who is the best, etc etc etc.
Old Sep 18, 2006 | 10:40 PM
slickman's Avatar
slickman
Yup, that looks like very minor work..
Old Sep 19, 2006 | 12:20 AM
shr's Avatar
shr
i wish i had that problem[&o]....owell, i would sand down the floor to see how bad the rust actually is, if its confined to that area then small patch, if its further out put the whole pan in on that side and stick a fork in it
Old Sep 19, 2006 | 04:07 PM
Lumbergh's Avatar
Lumbergh
Agree that you need to remove the rust from the area to see just how bad it is. Could get by with a single replacement panel or may need to go with a full length floor pan replacement on that side. Personally, I would remove the seat and pull the carpet and sound deadener on that side to get a look at the floor from the inside as well. The Mustang I purchased recently looked fine from the underside, but after I got it home and pulled all the carpeting and sound deadener out, I took a wire wheel to the floor to remove the "minor" rust. I'll be replacing the driver's side floor pan now.
Oct 26, 2015 05:01 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
cbird1177711
Sep 3, 2015 08:43 PM
