MSD!!!
Old Sep 19, 2006 | 02:57 AM
ADRIAN1's Avatar
ADRIAN1
Default MSD!!!
Ok, im ready to go into a MSD system. What ingnition box, coil, and distributor do you guys recomend?
Old Sep 19, 2006 | 03:19 AM
Gun Jam's Avatar
Gun Jam
Default RE: MSD!!!
get the msd a6, msd 45k coil, msd 8mm, msd distribuitor. Works fine for me been several years with no problems at all
Gun
Old Sep 19, 2006 | 03:56 AM
Volcom66's Avatar
Volcom66
Default RE: MSD!!!
I say 6AL L stands for limiter so you dont blow your engine. I like my pro billit dizzy and blaster 3 coil works great
Old Sep 19, 2006 | 04:04 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: MSD!!!
+1 its a sweet setup
Old Sep 19, 2006 | 03:10 PM
edgars23's Avatar
edgars23
Default RE: MSD!!!
I have a 6A, it is a great box, but i do wish I wouldve spent the extra cash on the 6AL for the rev limiter. Does provide a sense of security.
-Edgar
Old Sep 20, 2006 | 03:28 AM
65andonly18's Avatar
65andonly18
Default RE: MSD!!!
could someone explain further the difference of the 6a and 6aL dumb i know but i want to see if its worth the extra bucks?
Old Sep 20, 2006 | 07:57 AM
Brandontyler65
I ♥ Acer
Default RE: MSD!!!
well its simple they are the same except the 6aL has a rpm limiter in it hence the L
Old Sep 20, 2006 | 02:41 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: MSD!!!
The rev limiter in the 6AL drops a firing event from random cylinders on each firing cycle to keep the engine from going too high in RPM. It wont go over that no matter what you do.. well going down a steep grade of downshifting to first at 100mph will over rev your engine, but not under power.
I have the 6AL on 3 vehicles and the Mustang and Cougar will likely get them as well. It has saved the 455s a few times, since with stock rods they are rpm limited to around 5800-6000 rpm. Much over that and things come apart alot faster than you would expect. So miss a gear with the 4 speed, break teaction, or break the auto trans so it freewheels and you can over rev real easy. I did all three of those with the GTO, broke the 4 speed doin it.. lol.. Then broke 4 automatics behind that engine.. It grunts hard and moves a 4100lb vehicle real hard... mid 13s in street trim.
I would spring for the 6AL, peace of mind... and not much more $$$
Old Sep 20, 2006 | 03:41 PM
slickman's Avatar
slickman
Default RE: MSD!!!
I have the MSD Ready-to-Run and it seems to work great so far.
MSD Ready-To-Run
Old Sep 20, 2006 | 03:46 PM
ADRIAN1's Avatar
ADRIAN1
Default RE: MSD!!!
ORIGINAL: slickman
MSD Ready-To-Run
i heard that you dont need a ignition box for that dizzy. true??
