low vacuum, exhaust backfire
I have a 351 cleveland that has a 3/4 race cam in it with around 12.1 compression(yeah, i know thats high). It has started to run really crappy, and has exhaust backfires like crazy. Also when you hit the throttle it is very slow to return to idle. I have checked the throttle spring and made sure it is fine and everything is free. It just doesnt seem to idle properly, and when i hook up a vacuum gauge i get a reading of about 5 pounds, it is a steady reading, the needle doesnt move very much. I have played around with the timing, and messed around with the idle mixure. The last few times it has been started it seems to have gotten worse. Any ideas?
Thanks
Matt
Thanks
Matt
Thanks for the reply,
I have the MSD timing controller which allows me to adjust the timing 7 degrees both ways. I havent touched the timing in over a year and it was running great not to long ago, the problem is pretty recent. I was just outside and pulled out osme of the plugs and found them to be carbon fouled really badly. There is no way that these plugs could all be firing properly. I am going to get some new plugs tomorrow, and see what happens. I have a feeling i was runnig to rich, and to make it worse i only go cruising around town. I never really opened it up on the highway. I guess that the unburnt fuel is getting into my exhaust and igniting, causing a backfire. Do you think that my carbon fouled plugs will cause these symptoms?
Thanks
Matt
Thanks
Matt
Hello,
I replaced the plugs and that made no difference, even though the gaps on the old plugs ranged from .025 to .035, i have no idea why but thats how they were. I also disconnected the electirc choke and unpluged the wires to see if it was the choke, still no difference. Each time i rev the car it is very slow to return back to idle, it will stay at 1500 rpms for a few seconds then drop down.
Any Ideas?
Matt
Any Ideas?
Matt
hmm i would guess rich condition now is this only when warming up or all the time it could be a float adjustment or excessive fuel pressure or the change in temps could be effecting your mixture these are also things to consider cause my car has probs here cause it runs gr8 in summer but until i tune it for winter i have probs like this
TfcCDR
Sep 14, 2015 12:08 PM
dalefrancis88
Sep 11, 2015 07:15 AM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
