Got my rear drums...
Old Sep 25, 2006 | 11:58 AM
baddog671's Avatar
baddog671
Default Got my rear drums...
So, I finally got my new rear drums for my 67 and I figured Id test fit them before I painted them. One goes on the passenger side, no problem. The other one refused to go on the driver side. I sat there trying to force it for acouple minutes and then gave up. So, I swapped places and it fit on the other side so I figured it wasnt the drums themselves. It looked like the shoes were getting in the way, the drivers side "stuck out" further. So, I started prodding and beating on it looking for a clue and a little piece fell off. I thought, "GREAT, i have no idea where that goes". SO I looked on the othersdie, figured it out, and then realized it was a spacer to shorten or lengthen the shoe space. So I notched it down and the drum fit fine.
Not really important but I figured it out myself so I was happy
Old Sep 25, 2006 | 06:24 PM
coda618's Avatar
coda618
Default RE: Got my rear drums...
Use the star adjuster to expand or contract the shoes. Really should put new shoes on with new drums so that they wear evenly. After you get the drums on, use the adjuster to expand the shoes just so they are barely toughing the drums and you can feel just a little resitence when spinning by hand. That is the back yard way. The correct way if you have a measuring caiper big enough is to measure the inside of the drum and then set the shoes with the drum of a hair less thant the ID of the drum.
Old Sep 25, 2006 | 09:20 PM
67t5ponycoupe's Avatar
67t5ponycoupe
That's the way buddy! Beat it till you break it and then figure it out. Are you really going to trust these brakes?
Old Sep 25, 2006 | 09:40 PM
shr's Avatar
shr
yep should of adjusted it before you beat it, you probably need that spacer for it to work properly...dont worry we have all been there
Old Sep 26, 2006 | 09:22 PM
baddog671's Avatar
baddog671
I didnt beat the shoes, I just pushed against them very hard And they dont need replaced because they look new...
And yes, Ill trust them to stop me..
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Sep 30, 2015 10:13 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
