Resto-mod Mustang
Old Sep 25, 2006 | 07:15 PM
robthedolphin's Avatar
robthedolphin
Default RE: Resto-mod Mustang
ORIGINAL: my1967stang
I'm looking to resto-mod my 1967 Mustang. I'm going to the the typical things (4 wheel disc brakes, Overdrive transmission, Rack and pinion steering, etc...), but I want to drop in a 4.6L engine from a 1996 to 2004 Mustang coupled with a six speed manual transmission (converted from an automatic). I want the motor to have all ODB II capabilities, including a DLC to help diagnose any problems it develops. I am also planing on running cats to use the downstream O2s (but cats only, no mufflers). I am wondering if anyone knows if any of this has ever been performed, and if any modifications have to be made to the car, engine, wiring, or computer to make this work.
Yeah, the compuers on those 67's use those old tube transistors. I would recommend updating it to a mac.
Old Sep 26, 2006 | 12:51 AM
BakoLuke's Avatar
BakoLuke
Soaring, the SN65 used a blown 4.6 Cobra engine with updated mechanical and electrical systems throughout (including AC, hydro-boost power steering and breaks, ABS, traction control, etc…)...They still had shock towers but they were not the typical '65 shock towers...
my1967stang, you should check out the SN65 project....it has lots of info on what you want to do...
SN65: http://www.sn65.com/SN65%20story.htm
Old Sep 26, 2006 | 04:12 PM
slickman's Avatar
slickman
Very cool link, they did the same thing I did with the grill...
ORIGINAL: BakoLuke
Old Sep 26, 2006 | 05:26 PM
65mojoe's Avatar
65mojoe
The only thing I don't like about SN65 is the front apron (or valance whatever you want to call it). The two little air ducts look like they just ran out of ideas and cut two holes in the front (although Im sure those are functionally needed to feed that cobra beast). I think they could have made a front apron that more closesly fuses the front bumper styling of the 03-04 cobras.
Old Sep 26, 2006 | 05:27 PM
slickman's Avatar
slickman
Yup, I know what you mean.. It almost looks like an after thought.
Old Sep 26, 2006 | 05:29 PM
65mojoe's Avatar
65mojoe
hell it would have looked better if they had just used the glass ones that have the intake scoop where the license plate usually goes.
Old Sep 26, 2006 | 05:42 PM
slickman's Avatar
slickman
That's very true, it would have looked much nicer. I would have put the signals between the grill and the head lights (were the gills are) and used the signal opening as the air ducts.
ORIGINAL: 65mojoe
Old Sep 26, 2006 | 09:42 PM
jarrettdad's Avatar
jarrettdad
You will have to remove the shock towers or at the very least knotch them. The 4.6 SOHC and DOHC are very close to the same size.
The only thing 65 about that car was the skin. Everything underneath is pure Terminator Cobra.
Old Sep 27, 2006 | 01:18 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
i would get a 93 mustang 302 cause its MAF EFI and it will fit and more than likely require light modifacation
Old Sep 27, 2006 | 01:22 AM
65mojoe's Avatar
65mojoe
^....Maybe not the 93 5.0's though because that was the first year they came with hypers. Go back a year to 92-- you'll get the same power ratings, same setup, only with forged pistons!
