before i order...
Old Sep 25, 2006 | 06:36 PM
atomsk680's Avatar
atomsk680
Default before i order...
new pushrods, would the old guildplates be reusable?
and would I need a new flexplate for my new torque converter?
Old Sep 25, 2006 | 06:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: before i order...
Do you have Tom Monroe's book? If not, you need to get it before you attempt any rebuilding of your engine.
http://www.amazon.com/How-Rebuild-Sm.../dp/0912656891
Old Sep 25, 2006 | 06:46 PM
THUMPIN455's Avatar
THUMPIN455
flex plate should be okay. Guideplates can be reused unless you are going up in pushrod diameter. 1/4" to 3/8" is a big jump.. not that anyone has 1/4" pushrods, just an example. Same diameter same guide plates, provided they arent worn out. it is a good idea to replace them, but not absolutely necessary..
Old Sep 25, 2006 | 06:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: THUMPIN455
So, how do you determine if the guide plates are worn out beyond tolerance?
atomsk680's Avatar
atomsk680
thanks thumpin, if it needs replacement when i get to it, i'll overnight ship them.
CubanoGT
Jun 26, 2015 08:38 AM
Tiffsobelle
AmericanMuscle.com
Jun 10, 2014 04:25 PM
Baggeds197
Feb 23, 2014 05:29 PM
FivePointToTheOh
Jun 6, 2013 09:45 AM
13GTCS
Apr 15, 2013 10:30 PM
