Gears....what do i need.
Old Sep 30, 2006 | 02:13 AM
Magiarn71's Avatar
Magiarn71
Default RE: Gears....what do i need.
ORIGINAL: atomsk680
if im using the same 8inch housing, same axles, and splines, couldnt i just get a trac loc carrier and bigger gears? would that work??
You could. It's easier to just replace the carrier with the gears already in it. Depends on what you can find.
Oh and be careful of eBay, some stuff looks good and inexpensive, but sometimes you're better off just buying it, and paying a shop.
Old Sep 30, 2006 | 02:37 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Magiarn71
ORIGINAL: atomsk680
im going to buy the gears and carrier and let the shop do the rest
Old Sep 30, 2006 | 03:01 AM
Magiarn71's Avatar
Magiarn71
Well I meant buy it like, buy it new. You bring junk to the shop and not only will you hear about it, you are probably out the dough.
Old Sep 30, 2006 | 03:17 AM
atomsk680's Avatar
atomsk680
ooo, i meant, im going to buy, new, the gears and such, and bring it to the shop
Old Sep 30, 2006 | 03:44 AM
atomsk680's Avatar
atomsk680
what is this?
http://store.summitracing.com/partde...5&autoview=sku
anyone?
Old Sep 30, 2006 | 03:45 AM
valley firearms's Avatar
valley firearms
Try these guys.
Randy's Ring and pinion
Old Sep 30, 2006 | 03:46 AM
Magiarn71's Avatar
Magiarn71
Did you get a quote from the shop? You may want to ask if you can slide in the installation kit that chillin was talking about. Save buying that stuff from the shop too.
Old Sep 30, 2006 | 03:47 AM
Magiarn71's Avatar
Magiarn71
ORIGINAL: atomsk680
what is this?
anyone?
It's a locker.
Old Sep 30, 2006 | 03:54 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Magiarn71
ORIGINAL: atomsk680
what is this?
anyone?
It's a locker.
[8D]
i meant, why is it different from something like
Old Sep 30, 2006 | 04:01 AM
Magiarn71's Avatar
Magiarn71
Here's a good read for ya, so I don't have to bleed fingers.
EATON
Eaton Posi? Locker? What's up with that? Seems you'd expect an Eaton Posi system to provide positive traction under any conditions, right?
Well, sorta…
And a locker? Seems a locker should be a differential with the axles locked together all the time… Makes sense, right?
Again, sorta…
Obviously, you can't have the rear axles locked together all the time. That would make turning a corner pretty tricky. And Eaton Posi? Well, keep in mind that's our trade name for the finest "limited slip" differential available on the planet.
Basically, the difference between the two is this: A limited slip differential sends power to the non-drive wheel based on input torque; that is, power coming to the axle from the engine.
So, when high torque comes to the differential and both wheels are on a high traction surface, like a drag strip or country road, and high torque is delivered to the axle, the clutch pack clamps the gears to the differential case. This clamping action is in proportion to the torque delivered. The higher the torque, the higher the clamping load.
The idea here is to prevent wheel slip -- at either wheel -- in the first place. If one wheel starts slipping before the other, the clamping force drops in proportion to the torque delivered to the slipping wheel.
The whole point of the torque sensing limited slip differential is to reduce the likelihood of wheel slip.
The locking rear differential locks the drive and non-drive wheels together based on wheel slip at the drive wheel, regardless of engine power input.
Basically a locker is better for the performance end, but not the best for street. Noisy and not as smooth.
