Gears....what do i need.
Old Sep 29, 2006 | 05:36 PM
atomsk680's Avatar
atomsk680
Default Gears....what do i need.
ok, Holley Finally got back to me. they recommend 3.55-3.70 rear gears. i have 3.00 right now and i want 3.55 with trac-loc.
so what all do need? Gears, Ring and Pinion, 3.55:1 Ratio, and some kinda locker?
http://store.summitracing.com/partde...5&autoview=sku
somethng like this?
and what do you guys think of this torque converter
http://store.summitracing.com/partde...2+4294791122+0
Old Sep 29, 2006 | 05:54 PM
chillininnh's Avatar
chillininnh
Default RE: Gears....what do i need.
You'll need the gears (ring/pinion), your choice of carrier (detroit locker/traction-lok/auburn etc.), bearings, shims, orings, a gasket etc. (these sometimes come in an intallation kit), traction additive, and ofcourse fluid. Take a good look at the axles when it is apart. I went through this about five years ago. I also had a 3.00 open and chose to replace it with an Auburn locking carrier with 3.70 gears and swapped the axles from 28 to 31 spline. All told the parts were $1250. Currie says this setup will withstand up to approx. 600HP. Even if you shop elsewhere, their site offers a wealth of info.
http://www.currieenterprises.com/ces...ll9inford.aspx
Old Sep 29, 2006 | 06:09 PM
chillininnh
How about one of these? Disk brakes, limited slip....the whole shabang.
http://cgi.ebay.com/ebaymotors/96-98...QQcmdZViewItem
Old Sep 29, 2006 | 06:11 PM
chillininnh
Or try this.
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Sep 29, 2006 | 06:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, if you have never built a differential before, I would advise that you either have it done for you, or have an expert help you. There is more to it than just taking out the old and adding the new. You might want to consider getting a 9" already built like the second pic he showed you. That would be my choice.
Old Sep 29, 2006 | 06:40 PM
atomsk680's Avatar
atomsk680
i was going to get everything i need and then take it to the local shop down the street.
chillin, those are good things, but i have an 8 inch rear, and im trying to stay cheaper. i dont want to have to tap into the money i have put away for 6 months insurance
Old Sep 29, 2006 | 06:44 PM
chillininnh
Ohhhh, didn't know it was an 8, I'm surprised. How bout these.
I'm not sure you can buy all the stuff you will need seperate and then have the 3rd member assembled by a shop for less than the above examples.
http://www.currieenterprises.com/ces...e.aspx?id=2149
http://www.currieenterprises.com/ces...e.aspx?id=1415
These are the two biggies and the rest of the stuff is gonna run at least another hundred plus the cost of assembly. Lemme tellya though, the payoff is huge, gotta love Posi baby. [8D]
Old Sep 29, 2006 | 06:57 PM
atomsk680's Avatar
atomsk680
ORIGINAL: chillininnh
yea, hmmm, too bad, i almost ordered a complete differential trac-lok, 3.00 gears for an8 inch rear for $325. tooo bad i couldnt get that in 3.55 gears.
Old Sep 30, 2006 | 02:01 AM
atomsk680's Avatar
atomsk680
if im using the same 8inch housing, same axles, and splines, couldnt i just get a trac loc carrier and bigger gears? would that work??
Old Sep 30, 2006 | 02:06 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You could just get the 3rd member and use the existing housing/axles. You'll save some installation money, see which would be cheaper.
You'll probably want to upgrade the axle shafts, though. Just to be on the safe side.
