help...
Old Sep 30, 2006 | 02:52 PM
eZ's Avatar
eZ
Default help...
Hi guys thanx for your help in advance. I by no means consider myself a mechanic but im trying. Im installing new leaf springs in my 64.5. I ran into a problem. The bolt towards the front of the car that bolts the springs to the frame will not come lose. I have tried sprying that gunk that is suppost to loosen bolts and hit it with a hammer 168 times. how would i go about removing that bolt so i can install the new leafs. thank you.
Old Sep 30, 2006 | 03:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: help...
The bolt is frozen (rusted). So, the only way to get it out is to cut it off at both ends inside the spring eyes. I used a reciprocating saw, but others have used air cut off wheels and even cutting torches. One poster repoted taking off the back shackles and twisted the spring back and forth until the bolt came loose.
Old Sep 30, 2006 | 04:35 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: help...
ORIGINAL: Soaring
x2
only way to get it done. Have you heard of a SAWZALL? Best tool you will ever buy, used mine just yesterday to put the 5.0 back in the F150.. dont ask...lol
Old Sep 30, 2006 | 04:38 PM
Twister's Avatar
Twister
Default RE: help...
heat works too....but the sawzall is easier
Old Sep 30, 2006 | 05:22 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: help...
how using sawsall to put in an engine is anywhere even in the realm of possible is beyond me....but strangely enough....i feel as if i understand what you mean.... can you say "jagged engineering".....?
Old Sep 30, 2006 | 05:49 PM
Sean W.'s Avatar
Sean W.
Default RE: help...
i had a bolt that was rusted to a part.. i just hit it with a hammer with a couple times and i was able to get it off.....
Old Sep 30, 2006 | 06:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: help...
Trust me, you could bang on this bolt until the cows come home, and it ain't gonna budge.
Old Sep 30, 2006 | 06:06 PM
induhvidyooul's Avatar
induhvidyooul
Default RE: help...
hey, i hate frozen bolts as much as anyone, but don't be so quick to cut it-- try heating, or try letting some bolt loosener set on it overnight-- cutting bolts kinda sucks
Old Sep 30, 2006 | 07:01 PM
jarrettdad's Avatar
jarrettdad
Default RE: help...
Go with the heat first.... If that dosen't work then get the recip out.
Old Sep 30, 2006 | 07:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: help...
I have already been down that road. I used the torch to get it hot, then dumped some penetrating oil on it hoping that the oil would suck into the bolt and rust. All I did was burn up the rubber. So, out came the recip and about 4 or 5 steel cutting blades. Worked for me.
