1969 Mustang Project
Old Oct 2, 2006 | 02:22 AM
ched454's Avatar
ched454
Default 1969 Mustang Project
Hello Everyone!
Just took possession of a 1969 Coupe from the original owner in California. The car needs some restoration work but also seems to have both brake and electrical problems. First question: car has four headlights, the outside two work fine low and high beam. Inside headlights don't seem to work at all. What triggers the inside headlights? Second question: The parking brake indicator light bulb was burned out so I replaced it. Now the light stays on whether the brake is set or released. Is there a switch attached somewhere near the parking brake mechanism to activate the light?
Old Oct 2, 2006 | 02:30 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: 1969 Mustang Project
well
1) umm the inside one if factory should come on with the brights on that yr but if not look for a switch that says foglight or if they are aftermarketthen look for a switch that doesn't fit
Old Oct 2, 2006 | 02:35 AM
Toddman0025's Avatar
Toddman0025
ORIGINAL: ched454
button on the floor next to the clutch pedal
Old Oct 2, 2006 | 03:15 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Toddman0025
ORIGINAL: ched454
yep, its there, took me a month to find
Old Oct 2, 2006 | 03:20 AM
Sean W.'s Avatar
Sean W.
me to, i had to call a friend of mine to ask what it was for once i found it.
Old Oct 2, 2006 | 03:41 AM
Soaring's Avatar
Soaring
I ♥ Acer
That's the high and low beam on my 65. Is that where you guys turn on your fog lights? I assume the inside lights on the grille are the fog lights. I have never seen a classic Mustang with 2 headlights on each side.
Old Oct 2, 2006 | 02:34 PM
dawtips's Avatar
dawtips
the outside headlights are low beam while the inside ones are high beam... the outside ones DO NOT do high/low beam
EDIT: I guess I wasn't thinking clearly when I posted... ignore this
Old Oct 2, 2006 | 05:50 PM
69FECoupe's Avatar
69FECoupe
The outsides on my 69 have high/low. The insides are just high.
Old Oct 2, 2006 | 05:52 PM
69FECoupe's Avatar
69FECoupe
?????? All 69's have four headlights, two on each side. The inners are mounted in the grille.
Old Oct 2, 2006 | 05:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 69FECoupe
But, most of the time, those are referred to as fog lights. I don't know why, because the fog lights we used to use were amber in color. A bright white light will just make the fog blind you even more.
