Timing Cover Question
Old Oct 2, 2006 | 03:36 PM
PReal's Avatar
PReal
Default Timing Cover Question
I broke a drill bit trying to extract a bolt that had broken in my timing cover. Do I have to remove the crank pulley and harmonic balancer to remove the timing cover?
Thanks,
Parker
Old Oct 2, 2006 | 05:39 PM
JohnnyK's Avatar
JohnnyK
Default RE: Timing Cover Question
I believe you do.
Old Oct 2, 2006 | 05:40 PM
JohnnyK's Avatar
JohnnyK
You'll need a new seal as well.
Old Oct 2, 2006 | 05:54 PM
BakoLuke's Avatar
BakoLuke
it looks like its welded itself in there...hit it with a sledge hammer!
Old Oct 2, 2006 | 05:57 PM
restomod66's Avatar
restomod66
Take the broken bolt out with an easy out, it is the simplest way to remove a broken bolt.
Old Oct 2, 2006 | 06:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
You not only have to remove the crank pulley and harmonic balancer, you have to take the radiator, fan and water pump out just to get to it. Once you get the timing cover off, you may still have enough bolt sticking out to use some large vice grips on it to slowly turn back and forth until it comes out. If not, the the ease out is the next step.
Old Oct 2, 2006 | 06:45 PM
BakoLuke's Avatar
BakoLuke
Soaring, he already has all that stuff taken out all ready...and the vice grips didnt work...it just ate away the bolt
Old Oct 2, 2006 | 06:47 PM
PReal's Avatar
PReal
I might try to knock out the drill bit and then try again with the extractor kit.
Isn't an easy out just basically a bolt extractor?
Old Oct 2, 2006 | 06:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: BakoLuke
Am I missing a post or something? Here is all I have to go on. You sound like you have a picture or something. >>>>I broke a drill bit trying to extract a bolt that had broken in my timing cover. Do I have to remove the crank pulley and harmonic balancer to remove the timing cover? >>>>
So, I was just answering the question about whether or not the crank pulley and harmonic balancer had to be removed. At any rate, if the drill bit is stuck in the bolt, you will need to knock off the chewed up bit, and use a harder steel drill bit to drill into that one to get it out. Carbon steel bits are worth their weight in gold. Take your time, and don't force it. Yes extractors are the same thing, but you will need the right size. Patience my dear friend, patience.
Old Oct 2, 2006 | 07:04 PM
BakoLuke's Avatar
BakoLuke
No you didnt miss a post...PReal lives around the corner from me
