4R70W
Old Oct 3, 2006 | 02:36 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default 4R70W
i want that tranny but i dunno if i need a control box or it is built into the tranny and all i have to do is connect power ground and shifter
Old Oct 3, 2006 | 09:30 AM
dodgestang's Avatar
dodgestang
Default RE: 4R70W
You need the control box.
If you do not want to source and install a control box, you can get an aod built with the same gearset and other internal peices fromther aode/4r70w (except for the e-controllers parts). That's what I have for my AOD.
Old Oct 3, 2006 | 12:47 PM
deadcarnahans's Avatar
deadcarnahans
Default RE: 4R70W
The TCS is $425.00
www.becontrols.com
It works great. Absolute tunability of shift points and line presure.
Old Oct 3, 2006 | 06:43 PM
Brandontyler65
I ♥ Acer
Default RE: 4R70W
i know its gr8 but its alot of money for daily driver i just want a good overdrive tranny i like the sound of your setup dodgestang how much did it cost you
Old Oct 3, 2006 | 07:02 PM
dodgestang's Avatar
dodgestang
Default RE: 4R70W
ORIGINAL: Brandontyler65
I spent alot.
But I built it 3 times so am I not a good source.
I spent 1600 or so for the first one
then 2000 or so after I broke it
then 1300 or so after I broke it again.
I would think that you can do the whole conversion for under 2k though. edit: that's with all new stuff.
Old Oct 3, 2006 | 11:29 PM
Brandontyler65
I ♥ Acer
Default RE: 4R70W
i could just get a PA AOD from Jegs or summit
Old Oct 3, 2006 | 11:58 PM
dodgestang's Avatar
dodgestang
Default RE: 4R70W
Well...I would recommend a lentech or art carr.
You can get an AOD case/core cheap and a decent tranny shop can install the 4r70w gearset and upgrade clutches and bands you need as well as a good shift kit for prob less than $1300.
Then you need the cross member, tvcable, converter, you can fab the linkage for next to nothing, yoke, driveshaft shortened and then fab up the connector for nuetral safety and backup lights.
There is a little more to putting in an AOD than buying the AOD unfortunately.
Old Oct 4, 2006 | 12:17 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: 4R70W
and the TV cable is the most overlooked and easiest to screw up part of it. if it isnt spot on, you have junk in short order. I really need to get better at building OD-E transmissions..
Old Oct 4, 2006 | 02:36 AM
Brandontyler65
I ♥ Acer
Default RE: 4R70W
i fig there would be a little work involved how hard is the tv cable and what is a tv cable and don't say its what give me a pic on my tv
Old Oct 4, 2006 | 03:30 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: 4R70W
The TV cable is the throttle valve cable. It takes the place of the vacuum modulator and uses a mechanical input to tell the transmission how much throttle angle there is to change line pressure, and shift points, among other things..
if its too tight, you get sky high line pressure. Too loose and you dont get enough to keep the clutches from slipping. Also the cable pull distance and throttle ar angle need to be correct. In other words, the cable has to come out a certain amount for a certain amount of throttle angle. So the mounting position on the throttle arm of your carb has to hqave the right distance from the pivot shaft or you will have gremlins poppin up everywhere..
FYI.. the E versions of transmissions dont have TV cable.. they have a controller instead.
