timing quesiton
Old Oct 7, 2006 | 06:07 PM
andykbob's Avatar
andykbob
Default timing quesiton
Hey. I have a question about when doing the timing. I have a 69 351w and after doing some reasearch, it seems that I should set it at 6-8 btdc. I when to set it to 8 and the idle started to get crappy, and when I went up to 4, the idle was very good. Should I set it where it Idles better? Or does that screw up power when the rpm's are increased? What should I do?
Old Oct 7, 2006 | 06:28 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: timing quesiton
The timing should be set to maximize vacuum at idle, while still allowing the engine to start easily when hot (not buck the starter). Of course, you also have to watch out for pinging and missing under load and/or at higher rpm's.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
