I-6 engine swap
Old Oct 8, 2006 | 04:33 PM
dusty6467's Avatar
dusty6467
Default I-6 engine swap
Hey guys, I'm new to the forum.
I'm currently about to take on a project of swapping an engine from a 67 Mustang to a 68 Falcon. Both are almost identical straight 6's. The tranny in the Falcon is a 4 speed manual. The tranny in the mustang is a 3 speed automatic. Other than that they're identical. Does anyone have any pointers, tips, or just stories they would like to share with me.
-Dusty
Old Oct 8, 2006 | 05:37 PM
DGA's Avatar
DGA
Default RE: I-6 engine swap
Should be easy enough however there is always going to be surprises
Go slow, make notes and/or pics as you go.
Have fun and good luck
Old Oct 8, 2006 | 05:50 PM
BakoLuke's Avatar
BakoLuke
I just finished an I6 swap on mine yesterday...i have tons of pictures and lots of info if you need any help
Old Oct 8, 2006 | 09:17 PM
deadcarnahans's Avatar
deadcarnahans
You will have to install a pilot bushing in the rear end of your crankshaft. It's a commonly stocked part at most good parts stores.
Or remove the one in the Falcon engine and reuse it.
Otherwise it sounds like you have everything you need.
It doesn't get much easier. Lucky you...
Old Oct 10, 2006 | 02:34 AM
dusty6467's Avatar
dusty6467
Awesome man!
Any pictures would help. And if I run into any problems I hope you don't mind if I shoot you a question or two.
Curious, what 2 cars did you swap the engines from and how long did it take.
Old Oct 10, 2006 | 10:33 AM
BakoLuke's Avatar
BakoLuke
no problem...ask away
Old Oct 10, 2006 | 07:14 PM
Mustang Boy's Avatar
Mustang Boy
all of the I6 except for the 250 r the same size pretty much and the swap is pretty straight forward take one motor out put the other one in and r u swappin trannies too or not
Old Oct 18, 2006 | 04:39 AM
dusty6467's Avatar
dusty6467
I won't be swapping trannies. Infact that's the only thing I think might take some work. I'll be taking the engine from an automatic to a manual.
Old Oct 18, 2006 | 09:17 PM
Mustang Boy
i dont remember if ur keepin the auto or manual but which ever it would be that hard of a swap and if ur keepin the manual i would recommend getting all new clutch parts cause i learned the hard way that if a clutch assembly sits for too long it craps out on u
it is basically a bolt in swap and if i remember right its only like 20 bolts max that will have to be pulled
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
