Lug Nut Problem
Old Oct 8, 2006 | 11:57 PM
Toddman0025's Avatar
Toddman0025
Default Lug Nut Problem
Recently got some Cragar SS wheels but the wheel studs don't stick out enough for most of the lug nuts I have found - is there a solution to this?
Old Oct 9, 2006 | 12:01 AM
Cannonball888's Avatar
Cannonball888
Default RE: Lug Nut Problem
You have to replace the wheel studs with longer ones.
Toddman0025
Ah nevermind I found some on ebay - are the Ford studs 7/16" or 1/2" ?
Old Oct 9, 2006 | 12:02 AM
Cannonball888
1/2
Old Oct 9, 2006 | 12:06 AM
6mustang6's Avatar
6mustang6
Those rims take a special lug nut. They slide through the wheel. I have a few around here.
Old Oct 9, 2006 | 12:07 AM
Toddman0025
OK cool these should work:
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
What's the deal with the center or offset washers?
Old Oct 9, 2006 | 12:17 AM
Scott H.'s Avatar
Scott H.
The idea is for the washer to cover the oblonged hole. This allowed Crager to do a "1 wheel fits everything but Rosie O'Donell" kind of thing.
Nice rims BTW,
Scott
Old Oct 9, 2006 | 12:30 AM
Toddman0025
I've heard if you install the wrong washer it will completely f--k up your driving, I can't find any guides as to which washer is correct for mine. Guess I need to call Cragar tomorrow!
Old Oct 9, 2006 | 12:53 AM
6mustang6's Avatar
6mustang6
You need the center washers, since your lugs are centered in the whole. If the lugs were closer to the spoke, you'd need the offset.... This is my theory.
Old Oct 9, 2006 | 01:40 AM
atomsk680's Avatar
atomsk680
i have cragar SS rims, you need longer studs, the PO of mine decided to replace lugs on all wheels, ran out anf used a different lug, totally ****ed up the nut and eventually spread to the rest of the bolts. i am going to get all new bolts and maybe nuts.
