Monte Carlo on today
Old Oct 9, 2006 | 07:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Monte Carlo on today
The Big Brown truck showed up today, and lo and behold he had my Monte Carlo bar that I ordered. So, after wrestling with it for about two hours, it's on. I didn't have to do much in preparation other than loosen the fender bolts and use a rubber hammer to convince the inner fender he had to move out a tad. I guess my shock towers had not moved any for all these 40 some odd years. That was the good thing about making it easy for me to put the MC on without much hassle. Other than that, she went on pretty easily. Now we will see if it makes Ol' Yeller's front end any stiffer.
PIC.....
[IMG]local://upfiles/10034/7ABC6D6AC0434A44865380BCE26C5C65.jpg[/IMG]
Old Oct 9, 2006 | 07:14 PM
earlymustang's Avatar
earlymustang
Default RE: Monte Carlo on today
so that just bolts on to existing apron bolts? no drilling?
be sure to give an update on how it rides.
Old Oct 9, 2006 | 07:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: earlymustang
The Monte Carlo bar was designed for the 65-66 Mustangs, so it just bolts onto one of the top apron bolts, and two of the side ones on each side. If you want to finish the top off with two bolts, then one hole has to be drilled and one bolt added. I will do that tomorrow. If you don't have an MC on your vert, you might want to consider it. It is really not the nightmare to put on as I have read that it was. See pic.
[IMG]local://upfiles/10034/86D96826247A47289A064F8F433C360A.jpg[/IMG]
Old Oct 9, 2006 | 07:26 PM
65mojoe's Avatar
65mojoe
looks good soaring, where did you end up getting that from? I like the choice of straight MC for the stock stangers, it looks good. Its always a good feeling to that after 40+ years, all it takes to get the thing in there is a little rubber mallet coaxing. That means stuff hasn't been tweakin on you
Old Oct 9, 2006 | 07:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 65mojoe
I got it from Texas Mustang. Yeah, I was all ready to jack up the car and let the suspension relax for a few days, then still have to coax it on. But, to my surprise, she went on fairly easily. Everybody should own a big rubber mallet.
Old Oct 9, 2006 | 07:53 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Looks like you'll have fun with that dizzy or spark plug wires....[&:]
ORIGINAL: Soaring
Old Oct 9, 2006 | 07:58 PM
EmperorOfChicken's Avatar
EmperorOfChicken
SO a MC WILL fit with factory AC!? Yaaaaaaaaaaaaaaaaaaaaaaaay Gots to order me one up!
Old Oct 9, 2006 | 08:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Colorado_Mustang
ORIGINAL: Soaring
Not at all. I thought the same thing before installing it, but all I have to do is remove the air cleaner, and the dizzy cap pops right off and clears the MC bar easily. Yeah, I have heard about the removable MC bar for that reason, but I really don't see a need for it on a 65-66 which is what the MC bar was designed for.
[IMG]local://upfiles/10034/97AEC679289946B28E827BBC745BD6FE.jpg[/IMG]
Old Oct 9, 2006 | 10:06 PM
H Dean's Avatar
H Dean
let me know how that helps...
I'm likely going to need go get as much stiffness as i can with my engine/trans swap coming in the near future.
Old Oct 9, 2006 | 10:44 PM
Shifty101Easy's Avatar
Shifty101Easy
soaring, i thought you got a chrome one for extremely cheap from one of those parts websites....?
