I Forgot
Old Oct 10, 2006 | 04:18 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default I Forgot
where does the hot wire for elec choke hook up to on the starter relay
Old Oct 10, 2006 | 05:17 PM
DrBob67's Avatar
DrBob67
Default RE: I Forgot
I don't know what kind of carb you have but if this helps I have a edelbrock carb with electric choke. I was told to hook it up to a power sorce that is only on when the Ignition switch is on. So mine is hooked up to the fuse box. If I remember right it is on the winshield washer circut. Mine is not hooked up to the starter relay
Old Oct 10, 2006 | 06:31 PM
dawtips's Avatar
dawtips
I had it setup the same way as DrBob67 until I switched to a manual choke
Old Oct 10, 2006 | 08:18 PM
Brandontyler65
I ♥ Acer
i think its the I on the solenoid
Old Oct 10, 2006 | 08:38 PM
Scott H.'s Avatar
Scott H.
The proper way is to have it on a circuit that has battery voltage only when the key is in Run position. Otherwise, the choke heater coil will be activated anytime the key is in accessory mode whether or not the engine is running.
As an example: You're at lookout point with your girl friend watching the submarine races, and you've got Marvin Gay on the radio nice and low. It's a cold night. about 5:00 am you decide it's time to head for home. First problem... battery is very weak from running not only the radio, but the heater coil in the choke all night. You get a jump start from a guy who shows up with his fishing gear. Only now the choke is full open because the choke is hot. So the car runs like crap. You finally make it back to her place by 8:00am. Her father gets up at 7:00 and has spent the last hour polishing his shot gun....
Had you wired the choke correctly (and had Ravins on) you could have snuck her home by 6:00am and not have had your car blasted with rock salt!
Hmmmm, somewhere I hear country music
Scott
Old Oct 10, 2006 | 08:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Scott H.
Scott
And when you do finally get a jump and get it running, those Ravins sound just great. No need for a radio. Here, take a read bud. Maybe this will help you out.
http://www.chip.com/buick/techtips/choke.html
Old Oct 10, 2006 | 08:50 PM
6mustang6's Avatar
6mustang6
BLAH BLAH RAVINS BLAH. I love the sound of my flows. I've heard my car for the first time today, with somebody else driving. I stood in my driveway, and my friend drove it up the street. AH, IT SOUNDS SOOO GOOD!!!!!
Old Oct 10, 2006 | 10:07 PM
Rorin67's Avatar
Rorin67
ORIGINAL: Scott H.
Scott
That's the funniest thing I've read in a long time!!!
[sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif][sm=funnypostabove.gif]
Amazing how a "choke wiring question" can inspire such imagination and creativity! Time to call Hollywood!!! [sm=pimp.gif][sm=pimp.gif][sm=pimp.gif][sm=pimp.gif]
Old Oct 10, 2006 | 10:36 PM
restomod66's Avatar
restomod66
Guys,
That story just chokes me up!!!!!!
Old Oct 11, 2006 | 12:18 AM
Scott H.'s Avatar
Scott H.
Needless to say neither restomod66 or I will be quitting our day jobs anytime soon.
Great pun though!
