rack and pinion?
Old Oct 10, 2006 | 11:33 PM
stangman67's Avatar
stangman67
Default rack and pinion?
are there any newer cars that the rack and pinion will fit on my 67?
Old Oct 11, 2006 | 12:10 AM
Scott H.'s Avatar
Scott H.
Default RE: rack and pinion?
Yes, they all fit. Most will fit in an empty trunk. Pretty much the rest will fit in the back seat. Worse case scenario you can strap it to the roof, or hood.
Not sure why you'd want that, but to each their own.
Just a hint. try searching on the word Rack in any classic forum. You will get an incredible amount of information.
Ssshhh! don't tell anyone. The search button is supposed to be a secret.
If you'd like to see a poorly done write up on the install of a Rack and Pinion kit designed for the classic Mustang, you can check the web page in my signature. Or do a google search on TCP, Randall's Rack, Flaming hemroids...Uh I mean River, Steeroids, Maval, Heidt's....
Good luck,
Old Oct 11, 2006 | 12:54 AM
6mustang6's Avatar
6mustang6
What are you smoking Scott? I need some........ or is it just exhaust fumes? i got plenty of that.
Old Oct 11, 2006 | 02:31 AM
andrewmp6's Avatar
andrewmp6
go to mustangdepot.com they sell kits
Old Oct 11, 2006 | 02:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 6mustang6
Scott is getting loose and giddy, but probably knows more about our old stangs than most of us combined.
Old Oct 11, 2006 | 04:49 AM
Shifty101Easy's Avatar
Shifty101Easy
this guy is prob going to not know your just ripping on him.....
to answer the question, yes there are rack and pinion kits made for classic mustangs. and i believe the taurus rack can be made to work......
Old Oct 11, 2006 | 01:05 PM
stangman67's Avatar
stangman67
yea a datsun 1200 R&P fits in the trunk very nicely
Old Oct 11, 2006 | 08:50 PM
Scott H.'s Avatar
Scott H.
Actually I was just clowning around.
But seriously, if you do a search on any of those names, you will find so much information No way could you read it all before retirement, unless your name is Evelyn Wood.
There have been a lot of people who have done these installs, then done good writeups (unlike mine) on their own web sites.
Check it out. Also search a few forums, for the same names.
As to new cars, almost all are front steer, which means the rack will not work. Well...let me clarify, it would take a serious amount of machining specialty parts for the rack itself, to make front steer rack work for rear steering. You could install a complete front end kit like the Heidt's I mentioned above. It comes with a rack.
And to make it even more complex, there are more options than just R&P to have really great steering.
BTW: Soaring is giving me way more credit than I deserve. There are quite a few exceptionally knowledgeable people on this forum, including Soaring himself.
Old Oct 11, 2006 | 09:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is also some info we stuck in the FAQ awhile back.
http://www.totalcontrolproducts.com/...3-rckmp-00.pdf
Old Oct 11, 2006 | 10:37 PM
6mustang6's Avatar
6mustang6
I'm knowledgeable. for the most part.
