Need Help
Old Oct 13, 2006 | 04:12 PM
rcdblink716's Avatar
rcdblink716
Default Need Help
I've already posted on this once and got some good response. I have tweeked my set up a little and wanted to get some more opinions. I know how important the right matching parts is for hp numbers and don't have a huge amount of experience with performance parts. SO here is what I have planned.
*Ford Sportsman Block
*Eagle Cast Crank
*Eagle Cast rods
*Probe forged 4 inch bore pistons
*Trick Flow Stage 2 Cam
*Ford Racing Lifters
*Trick FLow Track Heat Heads
*Crane 1.6 Rockers
*Parker Funnelweb Intake
*650 Speed Demon
*Dynomax Black Jack Headers
*Milodon pan and windage tray
*Melling high volume pump
*Fidanza Aluminum Flywheel
Any suggestions or help will be greatly appreciated, ya'll know much more than me. Thanks in advance.
Old Oct 13, 2006 | 04:16 PM
rcdblink716
Default RE: Need Help
O ya, it's a 347 (342)
Old Oct 13, 2006 | 04:28 PM
mlitz's Avatar
mlitz
i don't know what kind of crab you are running but if you contact quick fuel technologies (QFT) and give then you r set up bore stroke all that kids of stuff they will make a crab personally for you. (that is what my friend did on is cobra kit car)
also i have never herd of Parker Funnelweb? i personally would go edelbrock air gap but that is me
i would go comp cam for your camshaft and hooker for headers
this is just me though
Old Oct 13, 2006 | 05:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
Looks like a fairly good plan. I would consider the Weiand Stealth dual plane intake over the Parker Funnelweb though.
