289 engine
Old Oct 14, 2006 | 07:37 AM
frankaxelsen's Avatar
frankaxelsen
Default 289 engine
Can anyone tell me a little more on this 289. It's in a 65 mustang coupe. The casting # on the block reads--- C4OE-6015C with a date code of 3L6.
I'm not sure if this is a HiPO and if it's originally from a mustang. My thoughts after a little research is thta it is a HiPO block but NOT from a mustang given the date code.
Old Oct 14, 2006 | 10:53 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 289 engine
C= 1960 decade
4 =1964
O = Fairlane
E = engine engineering
3=1963
L = November
6 = 6th day of November
That is most likely a low compression D code 289 that was used in the 64 1/2 Mustangs. The Hipo K code engines did not come out until July of 64. So, you most likely do not have a K code engine.
Here is some information to determine if it is a HiPo or not.
https://mustangforums.com/m_766107/tm.htm
Nick Oliver
Oct 17, 2018 04:22 AM
rksnow1
Sep 14, 2015 08:46 PM
ryland
Sep 13, 2015 12:35 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Brian Emmer
Sep 9, 2015 02:50 PM
