problem need help
Old Oct 16, 2006 | 06:56 PM
rwcstang's Avatar
rwcstang
Default problem need help
well i took it out for a drive for the first time in a month and and everytime i used the turn signal it would short out my radio. any suggestions?
[IMG]local://upfiles/6730/C668519047CD4A9096C05A9B666643DC.jpg[/IMG]
Old Oct 16, 2006 | 07:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: problem need help
Whenever you store these old cars, you get a build up of moisture in the entire car to include the electrical system. Drive it daily for awhile then see if it still does the same thing.
Old Oct 16, 2006 | 07:57 PM
Cogtx's Avatar
Cogtx
ORIGINAL: rwcstang
Had similar prob after install of a grant steering wheel. Horn contacts were worn down causing backing plate from steering wheel to touch various wire connectors on the turn signal assy. Somehow, the radio would short out and stop working with signal was on. Was able to rig glass fuse ends over the horn contacts. This provided more space between backing plate and whatever wire was being touched. Just my two cents on your dilemma but Soaring may be right as well with the moisture/corrosion build up on these old electrical systems...good luck and keep us informed of your solution....
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
