idle in gear
Old Oct 18, 2006 | 05:00 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default idle in gear
well i have had this problem for a while now but now it sems to have gotten worse when the car is in Park or Neutral it idles so smooth and i think it idles high but as soon as i drop it into gear it shakes really bad but when i let of the brake it accelerates so smooth and is pretty quick but i cannot figure out whats up with the massaging mustang cause its annoying and second its rattling my emblems off and i want it to drive smooth BTW my right bank exhaust sounds like someone is punching a pillow when idling i have 67 coupe 289/c-4
Old Oct 18, 2006 | 02:33 PM
Brandontyler65
I ♥ Acer
Default RE: idle in gear
well i know it takes time but i need to know
Old Oct 18, 2006 | 02:56 PM
dodgestang's Avatar
dodgestang
Try 2 things.
1. New spark plugs
2. adjusting the 4 corner adjustments (mixture) on your carb
Mine idles at 900 in park and 750 in gear. Idles real rough and I started almost stalling all the time when I was at a dead stop (so much so that I had to kick it to nuetral to keep it running). I just put new plugs in and the old ones were gas fouled apparently from an small ignition problem I had that took me a while to get rid of. With the new plugs, it doesn't try to die at idle anymore with no other changes.
If you still stall, adjusting the mixture will help.
Old Oct 18, 2006 | 04:31 PM
Brandontyler65
I ♥ Acer
thats what i thought so i made it rich with no help then i leaded it and no help i was told that the msd box would make me go through plugs more but i took it out and it looked ok but maybe it is gas fouled i was thinking it was my torque converter maybe i should use platinum plugs
Old Oct 18, 2006 | 04:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like you just need a general tune-up.
Old Oct 18, 2006 | 06:48 PM
stang6790's Avatar
stang6790
I would check for a vacuum leak. This could cause the symptoms you are having. Check all of the vacuum hoses and connections as well as the intake and carb gaskets. Spraying some carb cleaner around the edges of the intake and carb while the engine is running can help you locate a leak. This will cause the idle to speed up when you spray it where a leak is.
Old Oct 18, 2006 | 07:38 PM
my1967stang's Avatar
my1967stang
I've read that a 289 Mustang should idle around 800 RPM + or - 100 RPM, though I'm not sure if that is in gear or not.
Old Oct 18, 2006 | 07:41 PM
Yonco's Avatar
Yonco
My 71 302 does something like that. Idles nice in park then once you shift, the load is so much, it starts to stall, or does( if not warmed up) it or idle REALLY low.... -Jon
Old Oct 18, 2006 | 09:38 PM
Brandontyler65
I ♥ Acer
i have checked the manifold no leaks i need to check hoses and i will put plugs in enem though these plugs are only a couple months old any recomondations for plugs
Old Oct 19, 2006 | 12:04 AM
6mustang6's Avatar
6mustang6
yeah, mine usuall idles around 900, and drops to 600 when in gear. My car picks and chooses when it's going to run good.
