Attempting a Granada Swap
Old Oct 20, 2006 | 06:44 PM
Frankus's Avatar
Frankus
Default Attempting a Granada Swap
My Stang is in dire need of a disc brake upgrade.
I've looked into the Granada swap. Seems to me like the best choice considering im trying to keep the budget as low as possible (in college, blah). Besides, it seems like a better idea to go beefier than lighter, considering the 65 itself is an iron sled.
Now ive seen several pages of swaps, but i want to know what I need to get/ and what i need to do from you guys. That way I can watch out for any wrongs you guys have done in your swaps.
Havent drivin the stang in months.
I miss it badly.
Old Oct 20, 2006 | 06:57 PM
whoafrdofdapolce's Avatar
whoafrdofdapolce
Default RE: Attempting a Granada Swap
you will obvisley need the spindils, calepers, rotors, and pads. if you get the setup dirictly off the car insted of from soneone who has alredy rebuilt everything you should at LEAST get new rubber brake lines that plug into the calipers. probly new rotors pads and rebuilt calipers woudl be your best bet. i got a duel master cylender and distribution block from a 85 mustang at the junk yard and it workes great. you will need new tie rods, order stock granada outer tie rods from any parts store and they fit into the mustang inners. maby new ball joints for the upper and lower control arms whal your at it. that will be all you need.
Old Oct 20, 2006 | 07:12 PM
Decurion's Avatar
Decurion
not to be a dick, but try a search and look in the FAQ section. tons of good stuff there!
https://mustangforums.com/m_732643/tm.htm
Old Oct 20, 2006 | 07:52 PM
2bav8's Avatar
2bav8
Its a great swap...
Been very happy with it.
A few things I feel are worth spending a little extra money on:
Adjustable Proporting valve
Stainless steel flexable brake line hoses
Heavy duty rotors
Another "nice" upgrade is the Baer trackers, but wouldn't be needed on a tight budget.
My write-up on the conversion is online at:
http://www.geocities.com/2bav8/granada.html
Old Oct 20, 2006 | 08:06 PM
Shifty101Easy's Avatar
Shifty101Easy
http://discbrakeswap.com/
easy. cheap.
Old Oct 20, 2006 | 08:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ha ha the 65 an iron sled its a feather weight they weigh in at somethin like 2800lbs
Old Oct 20, 2006 | 09:37 PM
Bulldog66's Avatar
Bulldog66
ORIGINAL: Shifty101Easy
easy. cheap.
Ordered these Today
300 bucks for disc brakes is just too nice to pass up.
Old Oct 20, 2006 | 09:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, Dennis has a nice kit, doesn't he?
Old Oct 21, 2006 | 02:14 PM
Frankus's Avatar
Frankus
Wow. Nice kit. Do I need to get a new tie rod too?
Edit: Just went to the FAQ section of the site. ok. So I guess what Im REALLY asking is that there is anything you guys needed that wasn't in the kit? People keep telling me I need to get a new tie rod.
and...
Some 65-66 Mustangs or pre 66 Falcons will not have enough toe out adjustment after the swap. The solution to this problem is to use the shorter Granada type tie rod adjuster sleeves, or to shorten the existing ones.
Is this cause for concern? Im going to get it alligned after the swap, and want it as simply as possible so they don't have a fit. It's practically illegal to have an older car in the Bay Area, and I doubt there are many that will accomidate me.
Time to run through the phonebook.
Old Oct 21, 2006 | 06:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Degin's kit now contains spindles that have correct geometry for all applications. He manufactures specific spindles for 65-66 and 67-73. The problem with toe adjustment and bumpsteer no longer apply. He also supplies the correct tie rods specific to the application. He has a special price of $445 + S&H for the kit. This offer extends to Mustang Forum members.
