Remove Small Door Window???
i wanna take off my driver door small window that u like push open, not roll up....im gona strip the paint off the door and want to get it done without scratching the window part....what do you suggest???
its a 68 coupe.... |
RE: Remove Small Door Window???
just for reference they are called quater window were i come from
its not the quarter window....that would ROLL DOWN into the quarter panel, its seperate from the main DOOR window....im talking about the small window on the door....do u know what i mean???
so if you remove the door panel and look to your top left or right (depending on what side of the car you are on) you will see 2 or 3 bolts cant remember exactly that are either 1/2 or 9/16 that you remove and the window should pull strait up and out of there
yeah....i did that and the bugger wont budge so thats why i figured id ask before i broke something....i will go try again....
it's called a vent window :)
ORIGINAL: 1965coupe it's called a vent window :) |
Mine don't whistle at high speed but I do notice that if I yank on it (yeah, yeah, no comments) from the top (gentle yank) it moves out about 1/8-1/4" on each vent window.
Other than not opening it by pushing on that spot, is there a way to fix it so it's more securely in place? |
ORIGINAL: Soaring ORIGINAL: 1965coupe it's called a vent window :) |
