ALUMINUM RADIATORS
Old Oct 26, 2006 | 12:40 AM
ford65stang's Avatar
ford65stang
Default ALUMINUM RADIATORS
Im restoring a 65 mustang 2+2 i need to order a radiator.... im going aluminum....
Does anyone prefer a brand or does it matter???
Old Oct 26, 2006 | 12:51 AM
Justin66GT's Avatar
Justin66GT
Default RE: ALUMINUM RADIATORS
I used a Be Cool in my 66. The fit is good but I don't like how they did the filler cap.
It's hard to get anything to work really well with the opening being so small.
Justin
Old Oct 26, 2006 | 01:21 AM
Aussie66Fastback's Avatar
Aussie66Fastback
why aluminum?
unless I were going some custom extra large size, IMO it doesnt make that much difference with aluminum vs standard provided it is in good condition and has a decent shroud. the biggest problem with the 66 is that the radiator is not wide enough not teh material it is made out of.
the only real issue with custom is fitment and hoses to suit.
aluminum copy of the stock radiator size and shape is easier to work with.
Old Oct 26, 2006 | 01:22 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I have a Jeg's branded radiator. It's good quality, but doesn't have a drain valve...[:@]
Old Oct 26, 2006 | 01:32 AM
Shifty101Easy's Avatar
Shifty101Easy
better cooling and rust free not even factored in......aluminum cuz it looks better
Old Oct 26, 2006 | 01:37 AM
ford65stang
im going aluminum for a few reasons....my car is going to be a weekend driver / show car / i can take it anywhere car.
i have a 289 bored out to a 306 pushing 400hp so i need to make sure the cooling system works, plus i dont like the stock radiators (overheat to much).
Old Oct 26, 2006 | 01:44 AM
Aussie66Fastback
ORIGINAL: Shifty101Easy
agree it looks better if you are prepared to polish it all the time, but in my case I'd have to paint it black to keep it hidden from the road ***** (we have pretty strict registration rule for left hand drive cars)
in my experience the rust and scale from the block and heater doesnt discriminate between alum and copper core when it comes to blocking them up
Old Oct 26, 2006 | 01:54 AM
Aussie66Fastback
ORIGINAL: ford65stang
niiiiiice. I hear what you are saying. My 302 is an est 380hp and it cools ok with a standard rad and a shroud, even on the track. It gets a bit too warm on a hot day in traffic, but its never boiled out on me. With no a/c i try to avoid driving it on those days anyway.
If i could, i would put a custom alum rad in, but to ensure its effectiveness in all conditions i would
1. still use a shroud regardless of fan choice
2. make sure there was no other way for air to get past the radiator frame except thru the rad and
3. cut the rad support frame where the std rad mounts to allow fitment of a wider radiator.
4. consider an electric water pump.
Old Oct 26, 2006 | 02:04 AM
bradleyb's Avatar
bradleyb
all about aluminum - thinking of acquisitioning this off ebay, sweet - when you pop the hood on this people are going to pee their pants
item: 300039746570
http://cgi.ebay.com/ebaymotors/64-66...QQcmdZViewItem
Old Oct 26, 2006 | 02:47 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: Colorado_Mustang
i got one from jegs also but mine has a drain valve i just bought mine recently and mine is for a 65-66 it was the direct fit version for 65-66 for 279$
