Charging
Old Oct 27, 2006 | 07:07 PM
BakoLuke's Avatar
BakoLuke
Default Charging
My battery keeps on dying. I took in my alternator and they told me there was nothing wrong with it. So i bought a new battery and the car starts up fine for about a week. Then the battery dies. Is there something draining the battery that i dont know about? any help would be appreciated
edit: its an I6 200 if that matters
Old Oct 27, 2006 | 08:32 PM
n8rfastback's Avatar
n8rfastback
Default RE: Charging
do you have any sort of stereo system in it? any lights that stay on or anything that would drain it. i would double or triple check the alt also
Old Oct 27, 2006 | 08:58 PM
moparmatt89's Avatar
moparmatt89
disconnect the battery after you use the car. let it sit for a week. If it doesnt die then something is draining it. If it does it is probably your battery or alternator.
Old Oct 27, 2006 | 09:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Go out at night and see if any interior lights are on. Also double check your glove box light switch to make sure it shuts off when the door is closed. Somewhere, you have a light that stays on.
Old Oct 27, 2006 | 10:21 PM
BakoLuke's Avatar
BakoLuke
i have pioneer 6x9s but i dont have an amp...and i dont even have a glove box light...im guessing i should?
Old Oct 28, 2006 | 06:29 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Voltage regulator....?
Old Oct 29, 2006 | 01:57 AM
Calixtus's Avatar
Calixtus
I'm having the same problem, but I'm assuming it is because I only drive it 2-1/2 miles to work and then 2-1/2 miles home, and even that is not every day. Never gets a chance to charge up. I have a brand new battery, but I haven't changed the coil, voltage regulator, or alternator. I did see a cool product at the store though, it's a trickle charger that you just leave in the car full time and plug in when needed.
http://www.partsamerica.com/ProductD...tnumber=SE112S
Recommends for use "on collectibles, street rods and other infrequently used vehicles." Hmmm... sounds like me!
Old Oct 29, 2006 | 01:08 AM
BakoLuke's Avatar
BakoLuke
I got a new battery, alternator, distributor, batter cabels and a voltage regulator...hopefully that does it
Old Oct 29, 2006 | 01:52 AM
heavensonfire's Avatar
heavensonfire
Went through this with a Trans Am battery kept getting drained for no reason. Turned out to be a hot wire with the stereo. The stereo wasn't staying on but all the lights on it were was really odd. Just another alternative if that doesn't fix it.
Old Oct 29, 2006 | 02:28 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if the top of the battery is dirty it could be the cause
