how to keep 67 vert from twisting?
Old Nov 10, 2006 | 03:26 PM
Beakabo's Avatar
Beakabo
Default how to keep 67 vert from twisting?
This is what i've been told. Get car level, replace or rebuild hinges get both doors lined up so body lines are str8 and doors work perfectly. Then brace the inside of the car with angle iron from front windshield to rear of the floors and from the tunnel to the sides of the car. I guess my question is has anyone here done complete restoration on a vert if so what steps did u go through to keep the car str8. This car needs everthing replaced underneath from frame rails to frame rails. I' m just at a loss as to where and how to start. I was also told to start with the inner rocker and do one piece at a time. Need help getting a couple of the puzzle pieces together .
Any advice on this would b great.
[IMG]local://upfiles/53278/787155564069492D9191736F00CF9BE6.jpg[/IMG]
Old Nov 10, 2006 | 03:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: how to keep 67 vert from twisting?
After you get the frame rails replaced, install frame rail connectors from front to rear and side to side and new torque boxes. Also, check under the hood to make sure the front to cowl brace is in good shape.
Old Nov 10, 2006 | 04:20 PM
muggsy's Avatar
muggsy
Check out this link...I have a 67 vert as well, I called this guy and spoke to him. He's cool and will talk your ear off...See the pics of the convertible under reconstruction...maybe there;s some good info for you.
http://www.midcomustang.com/frameandfloor.shtml
Old Nov 11, 2006 | 10:18 AM
DJMabe's Avatar
DJMabe
The site muggsy showed looks to be the best info I've seen for replacing frame rails. Why are you concerned with flexing? Is it simply because of the condition of your frame or are you concerned about flexing after you fix the frame issues? I have a 67 Vert but, all my frame rails and suppurts underneath were in pristine condition. I didn't have to replace any of that stuff. I did add sub frame connectors and the export bracing up top. Also, I welded in a 6 point cage with removable back and side bars. My car runs 10.0's and I don't have any flex issues with the car. Here's a few pics of the bracing.
Old Nov 11, 2006 | 09:05 PM
Beakabo's Avatar
Beakabo
The subframe looks good will probaly go with something like. Did you make those are did you buy someplace? My concern with the car twisting is that the car is so bad underneath that when I cut the rockers out the car will try and shift or move and I wont be able to get the new parts in and keep the body and doors str8. I plan to do just one rocker at a time and as long as I dont move the car it should b fine I hope. Right now the car is up on jack stands two under rear floor pans wher the back seat was and two under the support where the transmission was and I have the center tunnel supported. The rockers are level so I figure when I put the new one in just keep it level right?
Old Nov 12, 2006 | 12:30 AM
DJMabe's Avatar
DJMabe
I wish I could tell you but, I just don't know. Like I said, mine was pretty solid underneath so I didn't have to do any repairs the the underside of the car. I think you are on the right track but, I'm no expert. My subfame connector are custom. Good luck and keep us posted with your progress.
robcy
Suspension
Oct 27, 2015 11:14 PM
MasterLanMan
Sep 26, 2015 10:03 AM
12bigredstang
Sep 24, 2015 10:43 AM
MasterLanMan
21
Sep 16, 2015 03:26 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
