Rear Quarters
Old Nov 16, 2006 | 07:23 PM
john721's Avatar
john721
Default RE: Rear Quarters
stick to spot welding with a mig machine. brazing is possible for joining steel parts, but on sheet metal too much heat is needed to effectively join the pieces. stagger your welds to help eliminate warping.
Old Nov 16, 2006 | 09:37 PM
THUMPIN455's Avatar
THUMPIN455
Your car is gonna look like this too! Much better than the one in my avatar though.. Anyone wanna come up and stoke the fire for me so I can prime and paint this weekend? lol....
get an inexpensive mig welder. I have a little Hobart I use for body work. Its 110v so its portable and I can run it pretty much anywhere. It came with flux wire, but the gas works much better with less grinding needed. I have less than $800 in all of the stuff for it, including gas, helmet and two spools of wire. Its a good investment, you will use it all the time if you get one..lol. Same with a bead blaster and air compressor.. you would use them to death..
i have a 71 Firebird that had the rear section brazed on. the floor boards are warped pretty bad, and the upper joint was doone very poorly. it took alot of time to do a very crappy job on it, so a good job would take even longer. I didnt do the work but I know how long it takes to braze stuff of that scale..
[IMG]local://upfiles/14646/6314B3DCB19E4F6D95D79F5F0DDC9627.jpg[/IMG]
Old Nov 16, 2006 | 10:20 PM
sweet 65's Avatar
sweet 65
Couldnt it be tig welded half an inch at a time then the welds ground to end up with no warping or bondo?
Old Nov 17, 2006 | 12:37 AM
Ste7of1's Avatar
Ste7of1
Really cool links, Chillin'
Thanks
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
b8checker
Sep 30, 2015 07:11 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
