quick Q
Old Nov 19, 2006 | 06:21 PM
mlitz's Avatar
mlitz
Default quick Q
are bolt pattern on a 5 lug mustang is 5.5" correct
Old Nov 19, 2006 | 06:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: quick Q
No.... 4.5
Old Nov 19, 2006 | 06:33 PM
mlitz's Avatar
mlitz
Default RE: quick Q
OK thank you i could not remember
Old Nov 19, 2006 | 06:36 PM
mlitz's Avatar
mlitz
Default RE: quick Q
will these fit on my 68?
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 19, 2006 | 06:40 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: quick Q
Should unless the tires rub. The stock brakes should clear no problem. Thats the right pattern, 5x4.5
fyi 5x5 is for trucks and large GM B body type cars. 5x5.5 is also a truck size wheel. you could buy me a set of r my F150 if you like... I woudnt mind at all..
Old Nov 19, 2006 | 06:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: quick Q
You could even go up to 4.25 on the backspacing if you didn't get silly with the width of the tires.
Old Nov 19, 2006 | 06:48 PM
mlitz's Avatar
mlitz
Default RE: quick Q
no i think i am going with these ones
http://www.americastire.com/dtcs/fin...r=45&tc=NITHZ4
Old Nov 19, 2006 | 06:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: quick Q
A 225-50 is about the largest tire you can run. Those are good looking wheels even though they are made in China. That's one hellava tire. The ZR is rated at what? 130 MPH?
Old Nov 19, 2006 | 07:37 PM
Decurion's Avatar
Decurion
Default RE: quick Q
a 205/45??? Yikes! Thats small! I would go with the 225/50 soaring mentioned. And "Z" speed rating is 149+
Old Nov 19, 2006 | 07:43 PM
mlitz's Avatar
mlitz
Default RE: quick Q
well the problem is that i would have to run a biger wheel to run bigger tires. so here are my choices
http://www.americastire.com/dtcs/fin...INT&tpc=NITHZ4
